Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 09-26-2010, 07:09 AM
Libanio is on a distinguished road
CNC Programming
Hi guys
i am a totally newbie in cnc turning machining, as im used to work in conventional milling machines only and i would like to ask a little help about how to make the programmation to make some pieces that you can check in the link below.
http://www.mediafire.com/imageview.p...0u78rwd6zlk2nh
the intention is to make pieces like that with 140 x 25 of diameter (measures in millimeters), then i have others to make with same shape only dimensions change a bit.
the hole its not needed to make
we still thinking which the best steps to make the work
the material will be placed in cnc with about 148mm and 40mm of diameter (material provided by the client)
Material is: x10crwmovnb9-2
our machine is a cincinnati milacron falcon 200 with acramatic 1200
thank you very much in advance for any help provided
Alvaro Libanio
Are you using WCS for programming? Steve Arteman Mastercam 30 Yesterday 11:23 PM
Need Help!- G71 programming alphonse G-Code Programing 1 12-20-2009 07:05 PM
Programming help! please!? angelo.p General Metal Working Machines 2 05-15-2009 01:26 PM
Problem- PLC PROGRAMMING jp41558 General Electronics Discussion 5 07-31-2008 01:17 PM
CNC Programming mikemill General Metal Working Machines 5 12-30-2007 02:05 AM
