Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 08-25-2010, 11:45 AM
danielfdiaz is on a distinguished road
alarm code 39-41
We have been getting an Alarm code 39-41 on our Arrow 1000 CNC mill. It is happening when the spindle is starting up. It's becoming more frequent and is happening once or twice a day.
I am listing the alarm code Cause and Remedy that shows up on our screen. Anybody have any idea what is going wrong?
thanks
Danny Diaz
Machine Shop Supervisor
Softest Designs
Phone: (210) 697-8828
Fax : (210) 697-8827
E-Mail: D.Diaz@SoftestDesigns.com
alarm 39-41
Cause: the drive ready signal has been lost.
Input CR_AXES RDY(100:00/32 is off)
Remedy: KollMorgen BDS4 drives. Check the display on drives. the control volts, enable and drive ready L.E.D.'s should be on.
Check the other indicators for the nature of the alarm. Consult the axes control documentation for details.
we checked all 3 drive results below
X and Y Drive were the same
Control Volt = on
Enable = off
Drive Ready = off
Under Volts = on
Z drive
Control Volt = off
Enable = off
Drive Ready = off
Under Volts = on
Old 09-01-2010, 11:00 AM
mike_Kilroy is on a distinguished road
let me know if u still have the problem; we can help you diagnose the problem with the Kollmogen BDS4 drive and let you know if it needs repair of is just a loose wire or something.
Old 11-10-2011, 01:30 PM
MensorCorp is on a distinguished road
Alarm 39-41 "Drive Ready" here in San Marcos, TX
Mike,
Please contact me. We currently have the same problem with our Arrow 1000 VMC. It also happens after pickup up a tool while bringing up the spindle RPM and traversing to the part. We have had minor success in the past by cleaning contacts etc..... We also spoke with Mark Nichols with Mag, and he suggested that it could be the DC power bus between the drives and/or the M20 contactor. We measured voltages here in the neighborhood of 300VDC with only small drops in operations, none near the 185VDC that would trigger a shutdown. We have also been able to duplicate the failure by rapidly in "hand-wheel" operation, cycling the "y" axis.
My contact info:
Jason Otto
Mensor Corporation
201 Barnes Dr.
San Marcos, TX 78666
(512)396-4200 x242
Old 11-11-2011, 01:49 PM
Bob Rudella is on a distinguished road
When you check those contactors (spindle is M11, Kollmogen supply is M20) check them by measuring across the contacts. When you measure from Line 1 to Load1 you should see less than a volt or two with the contactor energized since you are measuring across a closed contact. If you see any significant voltage across any of the three terminals you have a burnt or intermittent contact. Last time I saw that code the spindle contactor was burnt in our 500 but phase to phase voltage measurements looked OK. Also feel free to slap it around while you measure.
Old 11-11-2011, 02:02 PM
Bob, good ideas how to check!
This brings to mind a $ 39 IR temp gun from harbor freight... they are good for looking at contacts to see if they are hotter than the surrounding ambient - shows they are not making good contact!
Of course the UV error too is almost instantaneous; you may miss it with a digital meter if it comes and goes only under heavy load (accel) or cut....
Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit
Old 11-11-2011, 02:06 PM
Danny, our guys called you yesterday as requested; hope they helped a tad? They thought you want someone LOCAL to come help diagnose/fix the issue; if so, I'd suggest you POST that - you may get replies....
Need Help!- Alarm code 123 VF-3 Nova Haas Mills 12 06-16-2010 02:48 PM
971 NMI in SLC Alarm Code bmhall317 Open Source CNC Machine Designs 1 02-26-2010 09:34 AM
Need Help!- alarm code 84 eva_1686 Mazak, Mitsubishi, Mazatrol 0 12-02-2009 06:32 PM
Need Help!- Alarm code 203-6 meszarosg Okuma 3 10-11-2008 03:17 PM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
