| Cincinnati CNC Discuss Cincinnati CNC machines here. |
Hi guys, hope that some one can help me out with this : I am not able to align tool drum , I have been told that , because of this alarm, tool data tables need to be reset : How can i enter or fill out tool data tables , in a CT control, These tool data tables they are all empty ! no data at all !! & also i can't modify any value There are 3 options at the Tool Data : 1 Pocket Tools 2 Tool file directory 3 Tool file data |
| First off make sure you have the key in the control turned to allow editing. I'm not sure what your question is but if what you are asking is how do you add a tool file to the tool library, you select option 3 tool file data This will take you to tool 1 data there is a soft key for tool types, press that key then select a tool type from the menu enter a description for the tool then press enter enter a length offset then press enter enter a radius offset if required (I always do not for comp purposes but for reference in case I forget the dimensions of the tool) pressing enter cycles through the values, and once you enter the last value it jumps to the next tool then you have a tool file entered hope this helps Joe |
| skudzuki : i probably did not explain clear enough , but you clearly undestand , Thank you ! The problem with this machine was that it lost parameters , some one else load it back & for some reason the job is not finished yet That's the reason why it alarms , error 1546 ,when we try to home or align tool drum : Because tool data or tool library is empty skudzuki : the thing is that no matter where the editing key is , it won't let me change or modify any of those values |
| Error mseeage Arrow 750 | masmith17 | Cincinnati CNC | 19 | 01-25-2012 06:29 PM |
| Arrow 750 with CT control error message 9036 | DEAN-O | Cincinnati CNC | 3 | 08-24-2010 12:13 PM |
| Cincinnati Arrow error 9036 HELP! | cncwork | Cincinnati CNC | 3 | 10-29-2009 08:35 PM |
| Arrow 750 Error 9178 | ivanfed | Cincinnati CNC | 1 | 09-09-2009 03:36 AM |
| Arrow 500 Drive Fault Error | macmub | Cincinnati CNC | 6 | 06-02-2009 12:46 AM |
