Results 1 to 5 of 5
Thread: Third party rebuilders
    Sep 2009
    Does anyone know of a shop that can rebuild the ball screw/nut for the Y axis on our Arrow 500. Cincinnati can't get a new one to us until Sept 3. We don't want to wait that long, plus the new one is over 4 grand. It's jammed near the front end. The motor and thrust bearings are OK. It's the Kollmorgan setup.
    Oct 2008
    uk
    hello what pitch and diameter is your ballscrew?
    i might be able to offer a replacement or there is a uk company that will look at the ballscrew to see if it can be re-manufactured. if there is uniform wear then it should be allright. if your interested e-mail me at mallardfizz@virginmedia.com
    regards
    mallardfizz
    Sep 2009
    Thanks for the reply, you always have good info. However, management decided to sent it to Cincinatti to evaluate for $500 (USD). If they fix or replace it they'll credit us the $500.
    Thanks Again
    Oct 2008
    uk
    hello again.
    ok but if yours is not repairable i can probably supply a new ballscrew and nut for less than 50% that Cinci quoted you. a repair to yours - if possible - would be less still.
    regards
    Mallardfizz
    Sep 2009
    Hi mallard, just remembered I forgot to get back to you on that ballscrew. I ended up fixing it myself. When I removed the assembly to ship it I found two inches of fossilized plastic (PVC & ABS) jammed between the rear of the ball nut and the large washer on the end of the screw. I would have thought the drive would be able to smash anything not solid that got in the way but this plastic hairball was TOUGH. I had to hack through it with an X-acto knife to free it and then it was smooth as silk and free as a bird. The oil impregnated plastic shavings must have re-plasticized from the pressure. Just goes to show action fixes more machines than pondering. Thank again for the assistance.
    1. The party is over!!! In Chatsworth anyway...
      By Scott_bob in forum Fadal
      Last Post: 04-10-2010, 11:07 PM
    2. Need A Quote- Makino Wire/Sinker/Milling Third Party spare parts
      By precixion in forum Want To Buy...Need help!
      Last Post: 11-29-2009, 01:20 AM
    3. 3rd party software for morbidelli author 600
      By dcamp@mind.net in forum General CAM Discussion
      Last Post: 08-13-2009, 06:37 PM
    4. Need Help!- Third Party source for CMOS batteries
      By Seeker in forum Controller & Computer Solutions
      Last Post: 04-04-2009, 01:32 AM
    5. Party Games (Family) Ideas Needed
      By Khalid in forum Trade Shows and Events
      Last Post: 02-19-2009, 03:36 AM
