Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 08-06-2010, 07:53 AM
REBCOMACHINE is on a distinguished road
Arrow 500 1996 trouble a2100
I recently aquired this machine at auction. Thanks to all the support at this site I have replaced the hard drive with one off ebay. It is now showing a 4000f system fail, which is the dv5 board I quess. Here is my question, when I power up the machine the contactor that powers the dc bus is never engaged, the drives are showing undervolts - duh. All 3 axis appear to be at their limits. Do I need to manually move them off the switches before I can get them to power up? I cannot find any info in the schematic or manuals. I don't really want to screw this thing up if I can avoid it.
Any help is appreciated.
eric
Old 08-06-2010, 11:44 PM
cncatj is on a distinguished road
Hi ReBco.
The contactor that you refer , it actually feeds with 3 phase volt. to DC power supply wich gives the DC 350 VDC
As long as you have a software related problem or e-stop condition you will not be able to see the *machine power required prompt*
In normal conditions , after this message appears , the power button
is pressed and the contactor should be energized & maintened,
Old 08-09-2010, 07:59 AM
OK, I see this on the wiring diagram. Thanks for the insight. CR5 is not closing- at what point is this relay closed? As soon as the cpu is turned on the fault light on the dv5 board lights up. Is this a bad omen? Just looking for a place to start. Also the i/o board has no fault or enable lights lit up.
thanks
for all help.
eric
I think I will reseat the boards and see if that works.
Old 08-10-2010, 01:07 PM
dadam's Avatar
dadam is on a distinguished road
arrow 500
Hi Eric
I just bought an Cincinnati Milacron Arrow 500 1995 from an auction in Germany. After installation and setup looks like SWARF REMOVAL TRAYS are missing.
**Please help me and make a picture with yours so I can replicate them.**
I have lot of documentation in English and German (programming manual just German, I'm looking for english) and if you need I can help.
david_d_dadam@yahoo.com.
David
Old 08-10-2010, 01:42 PM
underthetire is on a distinguished road
No power to the drives, etc would be totally normal with a CPU error. You said you got a hard drive off ebay, is it for the EXACT machine model? All the configuration data is on that drive, different i/o's or axis drives etc will cause big issues.
Old 08-12-2010, 04:32 PM
scudzuki is on a distinguished road
Originally Posted by dadam View Post
Hi Eric
David
Did you get the coolant tanks?
The trays would be pretty hard to replicate, it would likely require more than just pictures.
I can get some pictures for you in the next day or so if you'd like.
Joe
Old 08-13-2010, 07:30 AM
dadam's Avatar
swarf trays
Hi Joe,
Yes I got the tanks. Replicate it might be a big word for what I will do, but I need to do something. Please make some pictures with yours so I can figure out how to do it. I'll attach pictures to see what I get here.
correct email is david_d_adam@yahoo.com
David
ID:	112661   Click image for larger version
Old 08-15-2010, 07:37 PM
I'll try to get some pictures tomorrow.
Joe
Old 08-29-2010, 04:10 PM
I tried emailing you the pics today and it bounced.
Want to provide a valid email address?
Joe
Old 08-30-2010, 03:43 AM
dadam's Avatar
Hi Joe,
Sorry for that. Try this: blumapi@blumapi.ro as a company email , but old one should works, too. david_d_adam@yahoo.com[david(undersc...adam@yahoo.com]
David
Tool Changer Messed up Arrow 500 A2100 Pau2752 Cincinnati CNC 3 04-27-2011 01:37 PM
A2100 - Arrow 1000: Operating System Lost JTG2003 General CNC (Mill and Lathe) Control Software (NC) 2 04-08-2010 10:33 PM
Arrow 1000 spindle trouble raygun Cincinnati CNC 3 03-02-2009 09:32 PM
A2100 and tool probe Arrow brokenrinker Cincinnati CNC 4 01-23-2009 03:37 PM
Need Help!- trouble to align cincinnati arrow 1000 (1998) aherrc Servo Motors and Drives 0 03-07-2008 05:16 PM
