Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 07-21-2010, 01:45 PM
Pau2752 is on a distinguished road
Tool Changer Messed up Arrow 500 A2100
My tool changer is messed up. When I call for a tool the wrong tool gets piced up. For example is I call tool 5 tool 12 gets picked up. But the screen says I have tool 5. Is there a way to change something in the control to get this back to normal.
Old 07-26-2010, 09:14 PM
laka is on a distinguished road
Look in your tool setup screen. The first two columns on the left I think. They should read something like:
1001 1
1002 2
1003 3
etc...
Sometimes if ours has a bad alarm or power outage in the middle of program and we start it up these numbers get messed around and it won't grab the right tools. If there is no tool in the spindle, all of the numbers in those two columns should be filled out. If there is a tool in the spindle it will change the number from whatever tool # to zero.
Hope this helps?
Old 08-03-2010, 02:52 PM
stevewortley is on a distinguished road
I think there is a setting for migrating tools on the a2100 this could be giving you problems.
Check the tool # against the pocket # and see if this corresponds to the tool being picked up. When my toolchanger played up I deleted all tools and started again with add tool and choose t#1 in pocket #1 etc not to bad if you dont have many tools. Also I only use active tool list.
Old 04-27-2011, 01:37 PM
Dixieplastics is on a distinguished road
I am having similar problem. Details on my open thread.
Please let me know how you fixed it.
Tags
carousel problem.
Hoss 16 Tool Automatic Tool Changer hoss2006 Benchtop Machines 316 03-03-2011 03:29 PM
A2100 - Arrow 1000: Operating System Lost JTG2003 General CNC (Mill and Lathe) Control Software (NC) 2 04-08-2010 10:33 PM
A2100 and tool probe Arrow brokenrinker Cincinnati CNC 4 01-23-2009 03:37 PM
Need Help!- Tool Changer picks up wrong Tool? KJ45 General Metal Working Machines 6 03-13-2008 06:51 AM
messed up tool path dertsap Mach Software (ArtSoft software) 6 07-16-2007 10:12 PM
