Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 05-14-2010, 01:55 PM
AMI AMI is offline
AMI is on a distinguished road
Question Rotary axis (A Axis)
how do you set the diameter of the part, when you are making a slot around the circumference, when ever I give a feed rate its to slow and takes ages to index in G01, I have used Haas, and setting 34 sets the diameter and feed is adjusted accordingly,
another way is to just put in higher feed rate but that requires alot of editing in each block of the program when running in xy and or a exclusively. I would appreciate if some on can assist
A 5-axis CNC machine including a rotary axis synthetiklone CNC Wood Router Project Log 11 05-23-2012 09:31 PM
How to zero a rotary axis jeffrey001 DIY-CNC Router Table Machines 5 07-21-2011 08:48 AM
Rotary axis WinD84 LinuxCNC (formerly EMC2) 2 02-23-2010 12:54 AM
CNC Rotary Axis help:-( YANKS_RINKS Mastercam 4 06-10-2008 05:58 PM
Dro on a rotary axis. Smackre DIY-CNC Router Table Machines 7 01-16-2007 07:45 AM
