Looking for a place to purchase the bulbs for the front display, for the various
buttons on the control, cycle start, stop, coolant on/off x,y,z, etc any help would be great. Also how to dump all parameters out to a disk. The memory module in the back has some type of a memory card slot does anyone know what type?
I got mine from here
http://www.sunraylighting.com/search.asp
search for part number 452450
fix you right up.
Another member here turned me on to this source.
I don't know about dumping the parameters but I will PM you the procedure for writing the important stuff (offsets) down.
The control can be reloaded with s/w in the event of corruption and the only things specific to the machine are the parameters you will write down (which you would re-enter the same way) and the axis comp file (part of the software) which Rob Varney (the Expert) told me doesn't matter much.
Joe
