| Cincinnati CNC Discuss Cincinnati CNC machines here. |
Hi, Have noticed a few posts on this site that refer to tool setting and which address codes you need (or don't need) to call up tool length offsets. If you dig around in here you may find the relevant posts. Have only used (Vickers) Acramatic once and found it a little confusing at first with the many multilevel tool/fixture offset tables. As I recall there is a 'Tool Manager/Database' in which you input tool DIAMETER, as WELL AS a H & D offset table, so your code will be dependant on how you use the machine. You could use one or the other or a combination of both. There is a unique notation for defining loops and there are also plenty of ridiculous cycles in there to keep you busy. DP |
you're going to like it!!!! i'm guessing it's a A2100 on a VMC there is a pile of VERY helpful guys here in the zone that know about the A2100 and Cincinnati machines i wasn't involved in CNC until 2 years ago and this is what I learned on. the guy that had the arrow before me, gave me a 4 hour crash coarse (forgive the word "crash") on programing, tool change, the RAP functions, and various programing short cuts. It's a very easy program to learn. do you have the programing manual? if you do... read, read, read!! most everything else I've learned is from this site including trouble shooting and repair has this machine been in your shop long? if it's new to your shop, one of the first things you're going to want to do is backup the hard drive. take a look at this link... it will help http://www.cnczone.com/forums/showth...hlight=cloning i backed up mine just before Christmas - it's still fresh in my mind if you have questions good luck and enjoy Mac |
| would like to see a simple mill and drill, maybe bolt hole pattern program. G54-G59? height and dia. offset use, where to find it. As things stand at the moment, no one on the shop floor has a strong head for programming. They hire me in and throw a Aramantic Cincinnati at me. Im a Fanuc man of ten years plus and im feeling stumped on this controller. They are just chopping bits and pieces together to make things work for now looking to me for help. All i need is to know where to find things and a couple sample progams. Thier progams are very screwie and without thought. no progamming manuals in tacked. any help or direction would be greatfull. Last edited by stovepipesteve; 03-09-2010 at 10:24 AM. |
| Hello send me an e-mail to mallard@fizz58.freeserve.co.uk and i'll send you a programming manual (and an operating manual if i have one) and i will try to get you started. i was an application engineer for 10 years at the Cincinnati plant in Birmingham UK - were your machine was built - and teaching the control was one of the duties expected. i didn't teach much because i'm a little impatient but lets see if i've calmed down a bit now i'm older. regards mallardfizz |
| How's this for reference, this program has milling, drilling, tapping, threadmilling, all on multiple fixtures. Hope it helps, there isn't a lot of difference, just a few very key things that need to be just right. What CAM system, if any, are you using? I may be able to help with a post file specifically for the A2100 control. Best regards, John :G90 G70 G40 G94 (MSG, CINC PRGM #### - ALL 4 OPS) (MSG, PROVEN #/#/## by ### ) (MSG, ---------FIXTURE 1 & 4 ----------) (MSG, TOOL 1 - 1.5 SHELLMILL) (MSG, TOOL 2 - 1.5 SHELLMILL) (MSG, TOOL 3 - 1/4 CENTERDRILL) (MSG, TOOL 4 - #19 DRILL) (MSG, TOOL 6 - M5 X .8 TAPER TAP) (MSG, TOOL 7 - M5 THREADMILL - USES WEAR COMP!!) (MSG, TOOL 8 - 3/16 CENTERDRILL) (MSG, TOOL 9 - #30 DRILL) (MSG, TOOL 10 - #30 BOTTOM DRILL) (MSG, TOOL 11 - M4 X .7 TAP) (MSG, ---------FIXTURE 2 ----------) (MSG, TOOL 12 - 3/4 SPOTDRILL) (MSG, TOOL 13 - 21/32 DRILL) (MSG, TOOL 14 - 1/2 ENDMILL - USES WEAR COMP!!!) (MSG, TOOL 15 - 1.25 COUNTERSINK) (MSG, TOOL 16 - 20MM TAP) (MSG, ---------FIXTURE 3 ----------) (MSG,TOOL 17 -1/2 ENDMILL - USES WEAR COMP!!!) (MSG, --------------------------------------) :T1M6 (MSG, TOOL 1 - 1.5 SHELLMILL) N100G0G90H01X7.62Y2.505Z1.S900M3M08 N102Z.5 N104G1Z.0475F100. N106G1X.815F12. N108G3X.44Y2.13I.815J2.13 N110G1Y-2.13 N112G3X.815Y-2.505I.815J-2.13 N114G1X6.08 N116G3X6.455Y-2.13I6.08J-2.13 N118G1Y1.761 N120Y3.795 N122G0Z.1 N124X7.62Y2.505 N126G1Z.01F100. N128G1X.815F12. N130G3X.44Y2.13I.815J2.13 N132G1Y-2.13 N134G3X.815Y-2.505I.815J-2.13 N136G1X6.08 N138G3X6.455Y-2.13I6.08J-2.13 N140G1Y1.761 N142Y3.795 N144M26M9 N146G0Y5.5 N148M00 (MSG, CHECK THICKNESS OF SHELF) :T2M6 (MSG, TOOL 2 - 1.5 SHELLMILL) N150G0G90H01X7.62Y2.505Z1.S1000M3M08 N152Z.5 N154G1Z0.F100. N156G1X.715F7. N158G3X.34Y2.13I.715J2.13 N160G1Y-2.13 N162G3X.715Y-2.505I.715J-2.13 N164G1X6.08 N166G3X6.455Y-2.13I6.08J-2.13 N168G1Y1.761 N170Y3.795 N172M26M9 N174M01 :T3M6 (MSG, TOOL 3 - 1/4 CENTERDRILL) N176G0G90H01X2.34Y2.695Z1.S700M3M08 N178Z.1 N180G83J13Z-.307R.1K.0350W0.F1.07 N182X4.43W0. N184X6.52W0. N186Y.898W0. N188Y-.899W0. N190Y-2.695W0. N192X4.43W0. N194X2.34W0. N196X.25W0. N198Y-.899W0. N200Y.898W0. N202Y2.695W0. N204G80 N206M26 (MSG, ---------FIXTURE 4 ----------) N208G0G90H04X0.Y0.Z3. N210Z.1 N212G83J13Z-.321R.1K.1050W0.F2. N214G80M9 N216M26 N218X-12. N220M01 :T4M6 (MSG, TOOL 4 - #19 DRILL) N222G0G90H01X.25Y2.695Z1.S1110M3M08 N224Z.1 N226G83J13Z-.825R.1K.1000W0.F2.124 N228Y.898W0.Z-.45 N230Y-.899W0. N232Y-2.695W0.Z-.845 N234X2.34W0. N236X4.43W0. N238X6.52W0. N240Y-.899W0.Z-.945 N242Y.898W0. N244Y2.695W0.Z-.845 N246X4.43W0.Z-.785 N248X2.34W0. N250G80 N252M26 (MSG, ---------FIXTURE 4 ----------) N254G0G90H04X0.Y0.Z3. N256Z.1 N258G83J13Z-.480R.1K.1W0.F2.5 N260G80M9 N262M26 N264X-12. N266M01 :T6M6 (MSG, TOOL 6 - M5 X .8 TAPER TAP) N268G0G90H01X.25Y2.695Z1.S0300M3M08 N270Z.1 N272G84.1J2Z-.645R.1K.0000P0.W0.F9.45 N274X2.34W0. N276X4.43W0. N278X6.52W0. N280Y.898W0. N282Y-.899W0. N284Y-2.695W0. N286X4.43W0. N288X2.34W0. N290X.25W0. N292G80 N294M26 (MSG, ---------FIXTURE 4 ----------) N296G0G90H04X0.Y0.Z3. N298Z.1 N300G84.1J1Z-.6R.1K.0000P0.W0.F15.75 N302G80M9 N304M26 N306M01 :T7M6 (MSG, TOOL 7 - M5 THREADMILL - USES WEAR COMP!!) N308G0G90H01X.2505Y.898Z1.S6586M3M08 N310Z.25 N312G1Z-.3F10. N314X.2519Y.8926Z-.2987F.8 N316X.2559Y.8887Z-.2974 N318X.2613Y.8873Z-.2961 N320X.2666Y.8887Z-.2948 N322X.2706Y.8926Z-.2934 N324G41X.272Y.898Z-.2921F1.6 N326X.2704Y.9062Z-.2902 N328X.2657Y.9132Z-.2882 N330X.2587Y.9179Z-.2862 N332X.2505Y.9195Z-.2843 N334X.2423Y.9179Z-.2823 N336X.2353Y.9132Z-.2803 N338X.2306Y.9062Z-.2783 N340X.229Y.898Z-.2764 N342X.2306Y.8898Z-.2744 N344X.2353Y.8828Z-.2724 N346X.2423Y.8781Z-.2705 N348X.2505Y.8765Z-.2685 N350X.2587Y.8781Z-.2665 N352X.2657Y.8828Z-.2646 N354X.2704Y.8898Z-.2626 N356X.272Y.898Z-.2606 N358X.2706Y.9034Z-.2593 N360X.2666Y.9073Z-.258 N362X.2613Y.9088Z-.2567 N364X.2559Y.9073Z-.2554 N366X.2519Y.9034Z-.2541 N368G40G1X.2505Y.898Z-.2528 N370G0Z.25 N372X.25 N374G1Z-.3F10. N376X.2511Y.8931Z-.2989F.8 N378X.2542Y.8892Z-.2978 N380X.2587Y.887Z-.2966 N382X.2638Z-.2955 N384X.2683Y.8892Z-.2944 N386X.2714Y.8931Z-.2933 N388G41X.2725Y.898Z-.2921F1.6 N390X.2708Y.9066Z-.2902 N392X.2659Y.9139Z-.2882 N394X.2586Y.9188Z-.2862 N396X.25Y.9205Z-.2843 N398X.2414Y.9188Z-.2823 N400X.2341Y.9139Z-.2803 N402X.2292Y.9066Z-.2783 N404X.2275Y.898Z-.2764 N406X.2292Y.8894Z-.2744 N408X.2341Y.8821Z-.2724 N410X.2414Y.8772Z-.2705 N412X.25Y.8755Z-.2685 N414X.2586Y.8772Z-.2665 N416X.2659Y.8821Z-.2646 N418X.2708Y.8894Z-.2626 N420X.2725Y.898Z-.2606 N422X.2714Y.9029Z-.2595 N424X.2683Y.9068Z-.2584 N426X.2638Y.909Z-.2573 N428X.2587Z-.2561 N430X.2542Y.9068Z-.255 N432X.2511Y.9029Z-.2539 N434G40G1X.25Y.898Z-.2528 N436G0Z.25 N438X.2505Y-.899 N440G1Z-.3F10. N442X.2519Y-.9044Z-.2987F.8 N444X.2559Y-.9083Z-.2974 N446X.2613Y-.9098Z-.2961 N448X.2666Y-.9083Z-.2948 N450X.2706Y-.9044Z-.2934 N452G41X.272Y-.899Z-.2921F1.6 N454X.2704Y-.8908Z-.2902 N456X.2657Y-.8838Z-.2882 N458X.2587Y-.8791Z-.2862 N460X.2505Y-.8775Z-.2843 N462X.2423Y-.8791Z-.2823 N464X.2353Y-.8838Z-.2803 N466X.2306Y-.8908Z-.2783 N468X.229Y-.899Z-.2764 N470X.2306Y-.9072Z-.2744 N472X.2353Y-.9142Z-.2724 N474X.2423Y-.9189Z-.2705 N476X.2505Y-.9205Z-.2685 N478X.2587Y-.9189Z-.2665 N480X.2657Y-.9142Z-.2646 N482X.2704Y-.9072Z-.2626 N484X.272Y-.899Z-.2606 N486X.2706Y-.8936Z-.2593 N488X.2666Y-.8897Z-.258 N490X.2613Y-.8883Z-.2567 N492X.2559Y-.8897Z-.2554 N494X.2519Y-.8936Z-.2541 N496G40G1X.2505Y-.899Z-.2528 N498G0Z.25 N500X.25 N502G1Z-.3F10. N504X.2511Y-.9039Z-.2989F.8 N506X.2542Y-.9078Z-.2978 N508X.2587Y-.91Z-.2966 N510X.2638Z-.2955 N512X.2683Y-.9078Z-.2944 N514X.2714Y-.9039Z-.2933 N516G41X.2725Y-.899Z-.2921F1.6 N518X.2708Y-.8904Z-.2902 N520X.2659Y-.8831Z-.2882 N522X.2586Y-.8782Z-.2862 N524X.25Y-.8765Z-.2843 N526X.2414Y-.8782Z-.2823 N528X.2341Y-.8831Z-.2803 N530X.2292Y-.8904Z-.2783 N532X.2275Y-.899Z-.2764 N534X.2292Y-.9076Z-.2744 N536X.2341Y-.9149Z-.2724 N538X.2414Y-.9198Z-.2705 N540X.25Y-.9215Z-.2685 N542X.2586Y-.9198Z-.2665 N544X.2659Y-.9149Z-.2646 N546X.2708Y-.9076Z-.2626 N548X.2725Y-.899Z-.2606 N550X.2714Y-.8941Z-.2595 N552X.2683Y-.8902Z-.2584 N554X.2638Y-.888Z-.2573 N556X.2587Z-.2561 N558X.2542Y-.8902Z-.255 N560X.2511Y-.8941Z-.2539 N562G40G1X.25Y-.899Z-.2528 N564G0Z.25M9 N566M26 /N568M00 :T8M6 (MSG, ---FIXTURE 1 LONG HOLDERS---) (MSG, TOOL 8 - 3/16 CENTERDRILL) N570G0G90H01X1.38Y1.38Z1.S1000M3M08 N572Z-3.575 N574G83J13Z-.24R-3.575K.0250W0.F2. N576X4.76W0. N578Y-1.38W0. N580X1.38W0. N582X3.13Y0.W0. N584G80M9 N586M26 /N588M00 :T9M6 (MSG, TOOL 9 - #30 DRILL) N590G0G90H01X1.38Y1.38Z1.S1000M3M08 N592Z-3.575 N594G83J13Z-.42R-3.575K.0250W0.F2. N596X4.76W0. N598Y-1.38W0. N600X1.38W0. N602X3.13Y0.W0. N604G80M9 N606M26 N608M00 (MSG, CLEAN OUT BOX BEFORE TAPPING) :T11M6 (MSG, TOOL 11 - M4 X .7 TAP) N610G0G90H01X1.38Y1.38Z1.S0300M3M08 N612Z-3.55 N614G84.1J2Z-.37R-3.55K.0000P0.W0.F8.267 N616X4.76W0. N618Y-1.38W0. N620X1.38W0. N622X3.13Y0.W0. N624G80 N626M9 N628M26 /N630M00 :T12M6 (MSG, ---------FIXTURE 2 ----------) (MSG, TOOL 12 - 3/4 SPOTDRILL) N632G0G90H02X0.Y0.Z3.S0300M3M08 N634Z.1 N636G81Z-.3R.1W0.F1.5 N638G80M9 N640M26 N642X-12. N644M01 :T13M6 (MSG, TOOL 13 - 21/32 DRILL) N646M42 N648G0G90H02X0.Y0.Z3.S0200M3M08 N650Z.1 N652G83J13Z-1.297R.1K.1500W0.F2. N654G80M9 N656M26 N658X-12. N660M01 :T14M6 (MSG, TOOL 14 - 1/2 ENDMILL - USES WEAR COMP!!!) N662G0G90H02X-.006Y0.Z3.S1250M3M08 N664Z.25 N666G1Z-.95F100. N668G41X.088Y-.0342F10. N670G3X.094Y0.I-.006J0. N672X-.094I0.J0. N674X.094I0.J0. N676X.088Y.0342I-.006J0. N678G40G1X-.006Y0. N680X.014 N682G41X.108Y-.0342 N684G3X.114Y0.I.014J0. N686X-.114I0.J0. N688X.114I0.J0. N690X.108Y.0342I.014J0. N692G40G1X.014Y0. N694X.0145 N696G41X.1085Y-.0342 N698G3X.1145Y0.I.0145J0. N700X-.1145I0.J0. N702X.1145I0.J0. N704X.1085Y.0342I.0145J0. N706G40G1X.0145Y0. N708X.015 N710G41X.109Y-.0342 N712G3X.115Y0.I.015J0. N714X-.115I0.J0. N716X.115I0.J0. N718X.109Y.0342I.015J0. N720G40G1X.015Y0. N722G0Z.25M9 N724M26 N726X-12. N728M01 :T15M6 (MSG,TOOL 15 - 1.25 COUNTERSINK) N730G0G90H02X0.Y0.Z3.S0200M3M08 N732Z.1 N734G81Z-.375R.1W0.F2. N736G80M9 N738M26 N740X-12. N742M01 :T16M6 (MSG,TOOL 16 -20MM TAP) N744G0G90H02X0.Y0.Z3.S0097M3M08 N746Z.1 N748G84.1J2Z-1.3R.1K.0000P0.W0.F5.733 N750G80M9 N752M26 N754X-12. N756M01 (MSG, ---------FIXTURE 3 ----------) :T17M6 (MSG,TOOL 17 -1/2 ENDMILL - USES WEAR COMP!!!) N758G0G90H03X2.695Y-.2829Z8.S1250M3M08 N760Z.25 N762G1Z-.45F100. N764G41X2.7292Y-.1889F10. N766G3X2.695Y-.1829I2.695J-.2829 N768Y-1.8171I2.695J-1. N770Y-.1829I2.695J-1. N772X2.6608Y-.1889I2.695J-.2829 N774G40G1X2.695Y-.2829 N776Y-.2646 N778G41X2.7292Y-.1706 N780G3X2.695Y-.1646I2.695J-.2646 N782Y-1.8354I2.695J-1. N784Y-.1646I2.695J-1. N786X2.6608Y-.1706I2.695J-.2646 N788G40G1X2.695Y-.2646 N790Y-.2463 N792G41X2.7292Y-.1523 N794G3X2.695Y-.1463I2.695J-.2463 N796Y-1.8538I2.695J-1. N798Y-.1463I2.695J-1. N800X2.6608Y-.1523I2.695J-.2463 N802G40G1X2.695Y-.2463 N804Y-.2458 N806G41X2.7292Y-.1518 N808G3X2.695Y-.1458I2.695J-.2458 N810Y-1.8543I2.695J-1. N812Y-.1458I2.695J-1. N814X2.6608Y-.1518I2.695J-.2458 N816G40G1X2.695Y-.2458 N818G0Z.25M9 N820M26 N822Y7. N824M02 |
| Rgds, John |
| HELLO, MY COMPANY RECENTLY PURCHASED THEIR FIRST CNC, VMC 2216 FX WITH FANUC CONTROL, ITS BEEN AWHILE SINCE IVE DONE ANY PROGRAMMING BUT FOR THE LIFE OF ME I CANT FIGURE OUT WHY IT WONT ACCEPT A SIMPLE BOLT HOLE PROGRAM. IVE ALWAYS USED MAZAK MACHINES WITH FANUC CONTROL BUT THIS CINNCINATI DOESNT SEEM TO LIKE ANYTHING I TRY TO DO... ANY HELP ESPECIALY WITH BOLT HOLES WOULD BE APPRICIATED |
#10
| bolt hole example i used in a hass fanuc. G90 G0 G54 X0 Y0 M8 G43 H1 Z1. S800 M3 T2 G98 G81 R.1 Z-.5 F4. L0 G70 I2.875 J90. L4 G80 G0 Z6. MOO G71 I2.875 J67.5 K45. L2--RANDOM PATTERN, IN PLACE OF G70 LINE G71 I2.875 J247.5 K45. L2-- |
| GE Fanuc & FANUC proprietary posts | CNCadmin | Fanuc | 44 | 01-05-2012 08:54 AM |
| FANUC & GE FANUC Repairs | RRL | Product Announcements & Manufacturer News | 1 | 04-17-2011 11:50 AM |
| can fanuc ac digital servo amplifiers be run by a controller other than fanuc? | js412000 | Servo Motors and Drives | 5 | 03-09-2011 09:11 AM |
| Fanuc & GE Fanuc Repairs | RRL | Product Announcements & Manufacturer News | 0 | 10-01-2008 12:42 PM |
