Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: Cincinnati a2100 Connectivity
    Mar 2010
    UK
    I have a 1998 Cincinnati Arrow 750 with a2100 control, I want help on how to get a laptop to converse with the machine's control to enable me to run larger programs from a cam package on the machine. The machine has low memory so will i have to Drip feed(DNC) the programs?, Also is this possible through the rs232 cable?
    Thanks in advance for your help
    Oct 2008
    uk
    hello its easy to 'drip feed' thru the a2100.
    select PROGRAMS
    TRANSFER PROGRAMS
    ADVANCED
    RUN WITHOUT LOADING.
    This will run the program from a host computer without using the edit buffer.
    send me an e-mail to mallard@fizz58.freeserve.co.uk with your e-mail or phone number if you want to discuss further. whereabouts in the UK are you.
    regards
    mallardfizz
    Nov 2006
    USA Texas
    You can also transfer the large program to the harddrive of the A2100 completely, then run without loading - which won't tie up your RS232 connection. This works better for me so I can leave a large program running on the Arrow, and get things done elsewhere also.
    You may need to create a seperate partition to the harddrive first though.
    Mar 2010
    UK
    Hi, thanks to you both for your replys. So what do i need to connect the two? ie software?? & usb to rs232 cable??
    Aug 2008
    Most CNC controls require a null modem cable.
    These cables
    http://www.cablewholesale.com/cgi-bi...ale+null+modem
    have the right gender for a DB9 on the computer, verify the gender and pin count of the connector on the control.
    edit: sorry I just noticed you're in the UK. Pity, these cables are cheap and good.
    I use this software for transferring files, and they claim it does drip feed, too.
    http://www.onecnc.com.au/nclink_free.exe
    Joe
    Nov 2006
    USA Texas
    You know the control computer is a PC running Window NT4.0 right?
    You can go the RS232 route and transfer using a DNC program like CimcoDNC, for which yes you'll need the USB to serial port adapter and a cable. This is not a user friendly method though, takes a bit to get it all set-up and working right. That is unless you have an older laptop that has the serial port on it and then you would only need to make yourself a cable.
    Or you can add an ethernet card to the computer in your A2100 control and set it up to access of a network and just drag drop the file over a network. This is how I have mine set-up and it makes my life so much easier.
    Dec 2009
    UK
    I have two cincci 500 with acro 2100. But I cant DNC one of them. (Just bought it).
    The machines ethernet option is available, and the floppy disk works. I am also 100% sure it is a software problem not hardware, and I get this strange feeling that I am just supposed to tick something and the problem will be solved.
    The control is very simple, (alot like a PC). its a shame they stoped making it. very user friendly, but does anyone know how to fix this?
    Nov 2006
    USA Texas
    Open the settings page on the one that is working and the other, then compare them. They both need unique IP addresses.
    You may check the ehternet card too, I've had one go bad and had to replace it.
    Rgds,
    John B
    Mar 2010
    UK
    Thanks john, Yes the ethernet is a option, but idealy i would prefer not to have that initial cost yet.
    Is it a worthwhile option for me to try and setup, rs232-usb connetion?
    What will i need and how do i do it?
    Basically i'd like the easyest way of getting large programs from a cam package to the control.
    I just hoped dnc would be easy and cheap?
    Nov 2006
    USA Texas
    Sure it's worth the time for the RS-232 method. Gotta communicate with it somehow and floppy ain't gonna cut it for long.
    There should be a DB25 port on the back panel, says "Printer" as I recall. That is where I initially had my DNC input connected. It's defined as Com1 as I remember. If you have the manuals, it's actually pretty good at describing the set-up. If not, drop me a PM and I'll get the info you need next week.
    Rgds,
    John
    Dec 2007
    Is there a work around for the ethernet without purchasing the option from Cincinnati?
    Nov 2006
    USA Texas
    First, install an ethernet card when the machine is off.
    Then try selecting the "Emergency Un-install" when the control is booting, which will cancel the Mustang load and go to Windows NT without the CNC operating sysem being loaded which will interfere with alot of changes in Windows. Then you should be able to set-up the ethernet card and all the IP stuff without the Mustang software being involved. Once the ethernet communications are set-up you should be able to reboot the machine and let it load Mustang as normal, and then have ethernet access.
    I have the harddrive partitioned off into 2 virtual drives so that only the new drive is seen from the network, which keeps someone from accidentally screwing up the operating system files. I transfer files from my CAM computer to the new virtual drive, F drive on my mill, and then I transfer them to the original C drive on the Arrow's control. If it is a large file I run it without loading, but there is never a problem with file size, the harddrive is originally 40 Gb, now it is 30Gb for the C drive, and 10Gb for the F drive.
    Rgds,
    John
  • Page 1 of 2 12 LastLast
    1. Replies: 5
      Last Post: 12-18-2009, 05:07 AM
    2. help on how to use a2100 rap
      By bronco079 in forum Cincinnati CNC
      Last Post: 11-28-2009, 09:11 PM
    3. Cincinnati A2100 Password
      By dominicmarceau in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 09-12-2007, 11:09 AM
    4. Cincinnati A2100 Migration System
      By Ben_Kristek in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 09-12-2007, 07:46 AM
