- Need Help!- Cincinnati 750 PSR
Cincinnati 750 PSR
Right where do I start. Well had a few problems with my new used arrow 750 and had my head in the cupboard for a few days. Ended up taking my psr out and checking the insides over. It had a blown fuse, a bad thyristor and one of the big blue capacitors was knackered.
Ive now changed all them. I watched someone test a fanuc power supply with a multimeter by sticking the neutral lead on the plus of the dc bus and the plus on the three wires at the bottom and gets a reading all close to each other. when I do it the same way but on the la lb lc I don't get a reading on the lc but I do on the others. I know there different units but I would of thought they should be. I'm no expert andI don't want to put back in and end up blowing it up. any help would be much appreciated.
Re: Cincinnati 750 PSR
We check the power supply the same way and we get the same reading on all 3 AC input lugs to the +DC output and the - DC output. It sounds like you have an open bridge rectifier on the one leg. You need to contact Chris at Kilroy was here
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
- You may not post replies
- You may not edit your posts
Forum Rules
