APC Rack 5 Communication Failure
Results 1 to 3 of 3
Thread: APC Rack 5 Communication Failure
    Oct 2011
    Dec 2006
    Default Re: APC Rack 5 Communication Failure
    You had the same problem in 2013 with rack 1 and you said that the switch on the module was in the wrong place, see the above (need help ). You may have a bad switch or a bad module. Try switching modules and see if the error stays with that module - don't forget to change the switches on both modules.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Oct 2011
    Problem is I don't know what the module is and which one is rack 5.
