- Need Help!- 850sx MMC board interchangeability???
I am working with a sabre 750/850sx with a dead mmc battery.
Is it possible to swap the MMC board from a different sabre? I am just trying to consider all options before shelling out $1500 for Siemens to re load the software
Re: 850sx MMC board interchangeability???
You should be able to swap the MMC boards if the machines are the same, with the same options.
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
- You may not post replies
- You may not edit your posts
Forum Rules
