- 1997 Cincinnati Arrow 1000 (A2100) - Communication Board
Re: 1997 Cincinnati Arrow 1000 (A2100) - Communication Board
I recently had a similar problem, there was a short on the cards I/O
You should look at the I/O card in the A2100 control, that is what turns on the relays. Also look at the AC ripple on the 24VDC supply by turning your meter to AC when connected to the DC supply, it should be under 1 VAC. Also look at all the connections and ribbon cables connected to the board and the A2100 I/O card.
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
- You may not post replies
- You may not edit your posts
Forum Rules
