- Need Help!- Cincinnati Arrow 750 FNC Tool Definition Problem
Hello,
I 've bought a used Arrow 750 VMC with FNC control. It was almost dead. I changed some pneumatic valves, pipe joint, limit switch. And I loaded a new software via serial port (CNC_COM). Now it seem ok. but I could not define tools.
I'm entering tool data, then pocket tools. A tool table appears but it is read only, Noting changeble. and there is a header message "(PROGRAM PROTECT)", I turned on and off protection key switch. but nothing changed. Do you have an idea what I'm doing wrong.
Regards.
Teknik Mekatronik
Ali Aslandas
- You may not post replies
- You may not edit your posts
Forum Rules
