Hello,
I am working with a Sabre 750 that booted up correctly at the shop I bought it from. Now that I have it wired here at home, I am having issues. It gets to the system startup page and all of the inputs pass. Then, it flashes "host control initializing" and doesn't go any farther. Does anyone have experience with this issue? I appreciate any help I can get.
Thanks,
Jeston
Hi
I'm having the same problem. please help me.
I am having trouble for turning the cincinnati Acramatic 850sx control panel.
my motor drive is siemens.
SUMP off
DIMP off
GMEM red
DAMP red
RUN yellow
OSA red
MMC red
SERV off
PCA red
DPWR green
APWR green
Display SYSTEM START-UP HOST CONTROL INITIALIZING
then there is no movement. waiting for help for this problem. thank you.Attachment 433451Attachment 433453
what is the answer
You can contact Cincinnati Tech Support at Fives-MSI with your Machine and control serial numbers.
It appears that while the machine was shut down the SRAM Battery on the MMC board has died.
You've lost the Machine Application Software (PMC, PLC), I-Sub & G-Sub Routines, Part Programs, Tool Data, Offsets, SYS COMM (System Parameters), MTB COMM (Machine Tool Builder Parameters), Servo Parameters, RS232 Device Parameters.
To get the Board repaired we would need the MMC Card Part number listed in the "Blue" Configuration Manual (three ring plastic binder) with Board Part numbers;
Software Loaded, Options Enabled, SYS COMM & MTB COMM Parameter listing and Servo Parameters and Device Parameters.
Without the "Blue" Configuration Manual (three ring plastic binder) you may have a major problem...
