Y Axis Encoder Error
Results 1 to 16 of 16
Thread: Y Axis Encoder Error
    Oct 2011
    Default Y Axis Encoder Error
    Hey guys, I bought a really nice 98 Arrow 500. Thing is like brand new. Spindle sounds great and cuts really nice and accurate.
    The issue here is with an intermittent "Y Axis Encoder Error"
    Machine will run fine for 3 days, then get 2 or 3 errors in a day.
    I would really like to get this sorted out.
    Y Axis Encoder Error-20170802_133248_resized-jpg
    Aug 2017
    Default Re: Y Axis Encoder Error
    I work with biesse mainly but when this comes up 99% of the time its just a connection either dirty or the connector where wire goes into sensors faulty also had the sensor itself be faulty change with another sensor repeat
    Dec 2006
    This machine does not have an encoder in the motor if it has BLACK drives by KOLlMORGAN. It has a resolver in the motor and the drive converts the resolver feedback to encoder TTL feedback for the A2100 control.
    If the drives are BLUE/WHITE it has a KOLLMORGAN SERVO STAR drive that uses an encoder. The Y axis motor wires do not move with the slide so I would suggest a loose wire or a problem in the drive due to heat. Do you have the fans working?? Did you check the tightness of the plugs on the motor and the drive. Are you getting a code on the servo star readout??
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Oct 2011
    Yeah, it has the black drives.
    I'm thinking abbot swapping the a axis drive from my other machine (I don't have a 4th axis) with the Y axis on this trouble machine to see if that fixes the problem. Do you see an issue in doing that?
    Dec 2006
    You need to look at the amps per phase and make sure it matches.
    Member mike_Kilroy's Avatar
    Sep 2010
    Sure it does not have linear scales?
    Sent from my SM-G900V using Tapatalk
    Mike@@@KilroyWasHere.com
  7. #7
    Dec 2006
    Good point MIKE K. A dirty scale would cause the problem. I have not seen a resolver cause an intermittent problem like that. Coop31 needs to inform us about having scales or not before he switches the drives.
  8. #8
    Oct 2011
    I do not believe it to have scales.
  9. #9
    Sep 2010
    Quote Originally Posted by coop31 View Post
    IIRC, you would be comfortable with swapping the encoder option card inside the drive? With another drive? The encoder emulation card plugs into a header on top of the main pcb in the drive... you could swap two drives cards to see if it is the card. Or swap the drives of course to help identify where the issue is?
  10. #10
    Oct 2011
    Yes I would be cool with doing that with a little guidance. Ive got a couple days of down time on these 2 machines, so I think I would go for just swapping the drives for now to at least isolate the problem to something in the drive. Then I could swap the encoder option card afterwards to prove that it is the problem.
    No as far as the 2 drives I want to swap, they both have the same model number (BDS4 206 23 412W32) so I should be good to go right?
  11. #11
    Sep 2010
    RIGHT!
    know the drive pots are tweaked to the axis so gains will be slightly off, but should let u test it... adjust speed scale pot if needed to get 1"/min/mil gain right (run 100ipm and adjust for .100" FE)
  12. #12
    Oct 2011
    Thanks for the help guys. I swapped the drives yesterday and the machine ran back and forth in Y for 7 hours straight. Going to let it do the same thing again today. Hopefully that's the end of my issues.
  13. #13
    Sep 2010
    Great! You know that some of us repair these drives so don't throw it away! It is worth fixing.
  14. #14
    Oct 2011
    Quote Originally Posted by mike_Kilroy View Post
    Yes, absolutely. You've fixed a couple for me in the past and I have sent a buddy of mine to you as well.
  15. #15
    Oct 2011
    Hey Mike, I opened up a drive to see about swapping the encoder option card. Looks like it is soldered to the main board. Does that sound about right to you?
  16. #16
    Oct 2011
    Never mind... I figured it out. Lol I'll swap them out on Monday and hopefully that works.
