The lathe will not run on single phase so you will need a phase converter. Purchase a dynamic phase converter that uses an electric motor connected to a 3 phase generator.
The machine should be 230VAC but check it out first. I always like to see the machine in running condition prior to purchase. How long has the machine been disconnected?
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
