Acramatic 2100 Realtime CPU Board BIOS from 1998.
Nothing wrong with the DV5 card even if the alarm says so!
Does anyone have the files to flash the bios on the realtime cpu board? Part number is 3-424-2168A03. I have the hardware req'd to boot the board, just need the proper files. I replaced the battery that was soldered to the board with a battery socket to make changing it easier.
Any help would be greatly appreciated!
Thanks!
Acramatic 2100 Realtime CPU Board BIOS 1998
Acramatic 2100 Realtime CPU Board BIOS 1998.
I tried until it worked. And this is the result for my machine. But not know if it is correct
What you have is the set up for the BIOS not the actual BIOS. I think it is dependent on the manufacturer if the RTC board that determines what BIOS is installed and the settings. Someone else may have more info on this or you could send the board back to SIEMENS or FIVES machine company to get it re-flashed.
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
The machine now works with the settings I've put on the pictures.
The machine works as usual again without problems, Bioset was from 1998.
Real-time board Item no. 3-424-2169A03. Returning if I find a problem arises. Wondering if it costs anything to get the card restored or is that free ??
Hi guys please
I have a Cincinati CNC machine ARROW 500, i have a problem with realtime cpu board part number is 3-424-2168A02 and error is NC Engine base failed.
And i replaced the battery and i need the bios programming file and set up for the bios
Many thanks
Hello Iheb , I have the same problem now , did you find the solution please ?
I'm having the same problem
Hello, I know this is an old post, but do you happen to know which jumpers need to be moved?
