Problem Gross Positioning Error Z 3D - morning start
Results 1 to 8 of 8
Thread: Gross Positioning Error Z 3D - morning start
    Member witbike's Avatar
    Jun 2015
    Poland
    Default Gross Positioning Error Z 3D - morning start
    Hello,
    I have a big problem. When I turn on the machine morning, after a few minutes make a Gross Positioning Error Z 3D... . This problem starts appear when my eletronic man remove a card from my machine. Then the axis make a quite buzzing. It is not a potentiometr, becouse I set it in optimal position.
    Sometimes after gross positioning error, when I turn on machine again machine show "XYZ axis not ready for operation". When the machine is hot this problem not shown again.
    i found it in manual, but I do not want change a parameter in MP for bigger value. I would like to find where is the problem. Somebody can help me?
    In attachment is the page from manual.
    Attached Thumbnails Attached Thumbnails Gross Positioning Error Z 3D - morning start-gross-pdf
    Dec 2006
    Default Re: Gross Positioning Error Z 3D - morning start
    It would help to know what machine it is and what control and drives it has!!!
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Jun 2015
    Poland
    I have Cincinnati Sabre 500 with Haidenhein 415. Te machine has fanuc servomotors.
    Dec 2006
    I can only assume that you mean Z axis error Y-D which indicates that your crossfire or stability is causing the motor\drive to vibrate when standing still. This is causing the following error to exceed the limits or window set in parameter MP1110. If you can look at the following error on the control it should be jumping a lot and the motor should have a loud noise coming from it and it should be hot. Not sure about your setup but I would contact FANUC to find out how to adjust it.
    Jun 2015
    Poland
    But why it is only when the machine is cold (morning)? The servo has normal temperature.
    My parameter in 1110 is 0,2 today I change it to 0,3.
    Nov 2012
    Quote Originally Posted by witbike View Post
    Hello,
    Is it possible the card isn't quite seated?
  7. #7
    Jun 2015
    Poland
    I checked every connectors and it look good. I disconnected them and connect again.
  8. #8
    Jun 2015
    Poland
    Hello again,
    I have a cincinnati (1000). When the operator put off a safety key we have Gross Positioning Error 3D! Sometimes it is when machine change a tool... Safety key has some connect with servomotors? Why can show gross positioning error when we move a safety key??
