- Need Help!- Headstock lathe lubrication recommendation
Hello,
I have start hearing a small noise in my headstock. I presume it is lack of lubrication (machine was bought second hand), and I am not sure if the headstock should be filled with lubrication, and if so, of what kind. I do not have machine manuals.
Can someone provide a recommendation?
Pictures attached.
Thank you very much.
Re: Headstock lathe lubrication recommendation
Sorry. It is a Falcon 200
- You may not post replies
- You may not edit your posts
Forum Rules
