Hey guys, I've decided to part out our once upon a time reliable Arrow 1000 as the motor's seized possibly from infrequent use plus being nearly two decades old and are likely to cost more to fix and floor space so hopefully the loss can benefit someone else.
Will add more to the list gradually, so far I've got:
1 x Vickers controller CPU box (51-A21001Y-3037)
1 x Input board 1269581
1 x Communication board 1269583A
1 x Output board 1269582
3 x BDS4
1 x VFS5
1 x PSR(250)
1 x Pendant
They say pictures say a thousand words so here they are, thanks gents!
sunnybank
Oh... pity. Servo motor bearing swap is a fairly easy job.
Are there three 10 amp BDS4s in the picture? Something tells me I could use a spare one.
Hey larspeed
Are the pics showing for you? Should be the second last one from the lot
Could see two different serials among them which are "BDS4 210 23 415V32" and "BDS4 210 23 414W32"
Both are same. Only difference is switch settings on plug in comp card. Change to match us or just swap card. So Lars peed both are good spares for u.
Sent from my SM-G900V using Tapatalk
Mike@@@KilroyWasHere.com
