Originally Posted by
JordanMach
Greg,
I am not perfect with the Cincinnati as I have only had my Arrow 2 1250C for a little over a year not and is my only one. i am self teaching myself the entire thing. First thing, you never attached any pictures to your post. 2nd, can we have more info? What drives do you have and what control? I assume the Acramatic 2100 (A2100), and possibly the Siemens Simo Drives? When I align my Z axis it never reads 0(Zero) as Zero is the table, so mine will read a Positive number. I will have to double check this Monday. As fir the Z not being blocked, that is strange to me. But It falling down a few inched while machine is off should not have confused the machine at all. As when you turn power off to your machine in shop, it will drop .100" before the Z axis brake engages. So I dont think there is in issue with the machine being confused from being lost from movement during shipping. I have torn all my axis apart on my Arrow 2 and have moved them all with machine off and havent had it be confused when turned on, that is what Axis Align is for.
Lastly, what is your exact issue? I know you say the Z doesnt read Zero and neither does the Y axis. But I dont think mine ever says Zero either. I will check Monday. The only issue I can see you are asking about is an error? But you never said what the error was? Also when you say it wont go below 20", is that truly 20" above table or is that what the system reads? Like is 20 your table and 35" the top of its limit? Like maybe its range is not aligned? Normally 0-20" but now is 20" to 40"?
Sorry, trying to gather all your thoughts, questions and concerns on this. I do know that my machine was a huge learning curve for me coming from all Fanuc 6 and Meldas M3 Controls.
Jordan
