Do you have the setup sheets for your machine??? You should not be adjusting the Kv Adjust. It should be 1.0 and the Kv Nominal should be at 2.0 on most machines. I can send you the setup sheets. Keep the RPM/volt at 205.4 and adjust the scale pot on the BDS4 drive for a KV Active of 2.0 when moving the axis.
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
