- Need Help!- question of Setup
question of Setup
is there way to active setup 2 or 3,4,6 in G code?
thanks Karl
Re: question of Setup
what controller? what machine?
hi
aramatic 2100
cincinnati 750 arrow
year 1996
thanks
Karl
i dit mean acramatic 2100 controll
You dont use G code. But you use the letter "H" for the part position. So "H1" is set up 1, "H2" Set up 2. Dont use the parenthesis though, just the H1, H2, etc.. The H1 is the same as a G54 and so fourth. I hope this makes sense? Here is a sample program I have in my machine. I am not saying my programing of the A2100 is perfect, but this gets me by. I am sure there are things I could fix in it to eliminate lines. For some reason I need to add a "Z" dimension in the line of my first X.Y axis move with spindle on otherwise I get an alarm for the Z. Also havent found a way I can just have the table go all the way forward with one simple programmed code, but instead I need to set up the part then do the calculation of the part position with the table forward. A pain in the rear if you ask me, I would like to use a "G28 Y0." line like I do in my HAAS to just bring the table all the way forward. I guess I slowly took over your thread. All i am saying is dont change your entire programming due to my post.
(PGM, NAME="ARROW.txt", TYPE="A2100_274", EXEMODE="STANDARD", PATH="PATHALL", ACCESS="OPEN", CREATED="FRI FEB 05 2016 15:42:02", MODIFIED="TUE FEB 23 2016 16:00:50")
:G0 G90 G40 G70 G17 G94
(MSG, PROGRAM NAME = Arrow)
(MSG, TOOL - 2 DIA. - .375)
(MSG, 3/8 MILL)
:T1M6
G0 G90 X-.2 Y.5315 Z5. H1 S3310 M3
Z.1M8
G1Z-.65F50.
G1X2.6345F39.7
Y.625
G0Z.1
Y-.625
G1Z-.65F50.
Y-.5315F39.7
X-.2
G0Z.1
Y.5315
G1Z-.65F50.
X2.6345F39.7
Y.625
G0Z.1
Y-.625
G1Z-.65F50.
Y-.5315F39.7
X-.2
G0Z.1
Z12.
M5
M9
M01
(MSG, TOOL - 1 DIA. - .375)
(MSG, 3/8 DRILL)
:T2 M6
G0 G90 X.562 Y0. Z5. H1 S715 M3
Z.1 M8
G81 Z-1. R0. W.1 F8.
G80
G0Z.1
M5
M9
M26
G0G90Y8.
M02
- You may not post replies
- You may not edit your posts
Forum Rules
