Contact Mike Kilroy at kilroywashere .com They are the Kollmorgan service company 937-660-5313 in the USA
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
Im looking for Motion Link software to communicate with a VFS5 Kollmorgen drive does anyone have a link thanks
here is link to the vfs5 manuals:
https://app.box.com/s/osd5j1nrus3ob1vdz2jx
and
https://app.box.com/s/uvzqestj2ui7e5nhd8o4
Here is link to the software to talk to it:
http://www.kollmorgen.com/zu-za/prod...ssioning_rev1/
you use std rs232 cable with ONLY 3 WIRES: db9 both ends, pin 3 to 2, 2 to 3, 5 to 5.
Thanks Mike
Hi Mike, I need VFS5 manual.
Can you help me?
Thanks Mike . please send it to lubominev@gmail.com
Hi Mike, I am also looking for the VFS5 Manual. Could you please send it to me? Jaysmachining@yahoo.com
Mike, could I please also trouble you for the VFS5 manuals. aharrington@yorkrepair.com . Thank you for any help you may be able to provide. Also, do you have a new link to get the software by chance. The above links weren't able to be found.
Hello, Mike
Need your assistance with VFS5 drive on Cincinatti Milacron Arrow 1000 (750).
As a result that BRAm Dallas hasn`t been changing for almost 25 years,
the settings that were in it have gone astray.
It looks like this: after turning on the machine, on VFS drive LED behave like this:
- Active: not illuminated
- System Ok: illuminated
- CPU: blinking
- Fault: not illuminated
- Relay: not illuminated
After connecting VFS5 to MotionLink we saw errors 80, 83, 84. In TL-file we saw that engine parameters are wrong.
After this connection VFS5 Spindle drive LED`s are:
- Active: off
- System Ok: on
- CPU: on
- Fault: off
- Relay: on
At the same time, the movement along the axes began to work, but the spindle does not rotate.
MotionLink continue to write errors 80, 83, 84.
BRAM was replaced.
Since we do not have files with parameters, please help remotely with the solution of this problem
on our machines Cincinatti Milacron Arrow 1000 and 750.
The problem is similar to the one discussed on this forum, but we can not solve it ourselves: https://www.cnczone.com/forums/cinci...are-forum.html
