- Problem- Cincinnati Lancer 1000 tech specs needed
Hi guys,
cannot find any technical specification on Lancer 1000 with Acramatic 2100. Can you help me? And if there are big difference in comparison with Sabre ? Need the following:
Table dimensions and allowed weight,
Spindle motor power with CAT (or BT) 40
Spindle speed max
Feedrate speed
Dimensions (!!!),
Weight (!!!)
Will be very appreciate!!
Re: Cincinnati Lancer 1000 tech specs needed
I think the Lancer's are Cat50
What type motors, spindle, drives?
If you send me the serial number of the control, I can let you know what manuals we have available on the Control.
Take a look.
Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
Lancer Specification
Units 1000
Longitudinal (table X axis) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . mm 1020
Cross (saddle Y axis) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . mm 762
Vertical (spindle carrier Z axis) . . . . . . . . . . . . . . . . . . . . . . . . . . mm 770
Range, spindle gauge line to work surface . . . . . . . . . minimum mm 225
maximum mm 995
Throat Depth . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . mm
Spindle (Snout) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . diameter mm
length mm
Table X--Axis
Work surface dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . length mm 1274
width mm 765
Load capacity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . kg 2000
Spindle Carrier, Z--Axis
AC Drive Motor (continuous rated) . . . . . . . . . . . . . . . (standard) kW 12.5
Spindle speed range . . . . . . . . . . . . . . . . . . . . . . . . . . . (standard) rpm. 40--6000
Number of speeds . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Programmable in 1 rpm increments
Tool Holder Type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . #50 ANSI/ASME B5.50--1985 std.
#50 ISO 7388/1--1983(E) std.
#50 DIN 69 871--1986 (part 1) std
#50 BT40 MAS 403--1982 (option)
Linear Axis Feedrates and Thrust
Feedrates . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . X,Y,Z mm/min 3--15000
Rapid traverse rate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . X,Y,Z m/min 24
Axis thrust (duty rated) . . . . . . . . . . . . . . . . . . . . . . . . . . . . X,Y kN 4
Z kN 10
Accuracies
Uni--directional positioning Z axis over full travel mm 0.004
Uni--directional positioning X and Y axis over full travel mm 0.003
Uni--directional repeatability per linear axis over full travel mm 0.001
Automatic Storage/Changer Unit
Storage capacity . . . . . . . . . . . . . . . . . . . . . . . . . Number of tools 30
Tool selection method . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Random by programmed tool
station number or tool ID
Tool and holder weight . . . . . . . . . . . . . . . . . . . . . . . . maximum kg 20
Tool drum load (evenly spaced) . . . . . . . . . . . . . . . . . . maximum kg 300
Tool length . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . maximum mm 400
Tool diameter (adjacent stations full) . . . . . . . . . . . . . . . . . . . . . mm 125
Tool diameter (adjacent stations empty) . . . . . . . . . . . . . . . . . . . mm 205
Automatic tool change time (metal to metal) . . . . . . . . . . . . . . . s 7.0
EXCELLENT Mike! Way to go!
- You may not post replies
- You may not edit your posts
Forum Rules
