- T-45 milacron Acramatic 950 programming in MCX7. post or sample code?
Our dealer does not have squat for a post for this and as much time as will go into getting them info, I might rather edit an existing post if I can find something close.
This machine has the full 4th on the table like any HMC but has vertical head tilt of 150 deg. Never done this and don't have sample code to look at.
Anyone have one of these? I think the magnum line might be the same programming wise.
Re: T-45 milacron Acramatic 950 programming in MCX7. post or sample code?
You can contact Master Cam for a post processor on a 950 control. You can also upgrade to V10 and have someone write you a post. Do you have the programming manual that came with the machine ??
Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
- You may not post replies
- You may not edit your posts
Forum Rules
