- Help! x-axis is alining in the wrong direction
Hello,
We have a Cincinnati sabre 750 with a acramatic 850 control. now for some reason after we moved the machine and powered it back up it comes up fine no alarms, but when we go to align it z homes y homes then x trys to home but heads in the + direction and it should home in the - Direction( if you just hold it it will go + till it hits the hard limit sw. I feel like this might off happened before I don't think anything is wrong with the machine, I believe it might be a g code or a offset of some sort if anyone has any ideas on how I can fix this please let me know im not very familiar with these controls. I work on fanuc most the time
Thank you for you time
Re: Help! x-axis is alining in the wrong direction
Sounds like you have an issue with a limit switch. Probably just dirty...
The X-axis align switch is stuck on. Clean or replace the switch in the front of the X-axis under the front sheet metal guard.
Mike cncmachineservices (dot) com
- You may not post replies
- You may not edit your posts
Forum Rules
