Results 1 to 6 of 6
Thread: Quick CNC tool changing problem
    Dec 2009
    Uzbekistan
    We have Quick CNC milling machine with auto tool changer (8 tools)
    When changing tool the spindle cover goes up, tool changer goes to the spindle and embraces the tool at the spindle and then makes nothing. Spindle should release the tool and go up to allow the tool changer rotate, but it doesnt release the tool, instead spindle blocked the tool hard.
    The screen shows that machine stopped at command M83.
    Please help if You know solution or can suggest smth.
    Aug 2009
    China
    There should be a light on on the tool magazine when the machine changing tools, I think the action should be after release the tool, the tool magazine backward to its position then the spindle lift up, has the tool magazine in the correct height? if not may be you need to ajust it, there is one nut in the middle of the turret besides the other 4 nuts, after ajusting the tool magazine, don't forgot to tight it up... I think the best way is to find the person directly who you bought the machine from... Good luck
    Website: http://quickcnc.diytrade.com
    Dec 2009
    Uzbekistan
    When tool changer reaches the spindle green light on the toolchanger switches on.
    I checked that spindle tool changing position is adjusted to the tool magazine.
    I emailed the person whom we bought machine, no answer yet.
    Aug 2009
    China
    Niyozov,
    I've informed my company about it, they are discussing about your problem, I'm sure you will get a solution soon...
    Dec 2009
    Uzbekistan
    Yes, company professionals helped to solve the problem!
    Because of time zone difference it took some 7-8 hours.
    The tool was just blocked in the spindle.
    They asked several questions, we did some tests and finally they proposed the solution.
    "Hold on F3 button and hit the tool with a piece of wood", then it was released.
    Thanks a lot! To the forum and company staff !
    Mar 2008
    Bangladesh
    Thumbs up
    that is why Rocket preferred this company! Thanks quick for solve that issue at short possible time.
    and Niyozov for sharing ur smile with us.
    keep it up
    1. Changing tool diameter in the tool offset screen
      By Vern Smith in forum Haas Mills
      Last Post: 09-24-2008, 10:54 AM
    2. Need Help!- Hitachi Seiki NF 20 FANUC 6T - problem with tool changing
      By Xavier M in forum Fanuc
      Last Post: 08-17-2008, 04:55 AM
    3. R8 tool changing
      By balibalistic in forum Benchtop Machines
      Last Post: 02-27-2008, 07:24 PM
    4. Sharp 2412 tool changing problem
      By longcut in forum CNC Machining Centers
      Last Post: 09-15-2007, 06:02 AM
    5. Tool changing G30.1
      By ben92 in forum G-Code Programing
      Last Post: 11-17-2005, 02:57 AM
