I'm using a Victor CNC Router since 2004. The worktable size is 900x700mm. I couldn't find much information about it at the time I bought it. I bought it entirely for cutting and engraving on acrylic, but occasionally I'm cutting some MDF too.
Here are the links I just found with information about the machine:
Official Victor Website: CNC Router VR0907 – CNC Router - Wood CNC Router - Laser Cutting Machine - Nanjing Viccam Technology Enterprise Co. ,Ltd.
Some other seller: Victor VR900 CNC Router - CNC Machines, Cable Protector, Drilling Hose: Kutenich Ltd. (My machine looks exactly like this, since it's 8 years old now. The picture on the official website if of a newer model.)
I had my share of problems and solved most of them. The main problem was that I didn't know anything about cnc routers at the time I bought the machine. There was nobody to help either. Even the company that did import and sold the machine to me didn't know anything about the machine. We figured out ourselves that the cutting head was water cooled. I have to adjust the rpm manually on a turn-knob at the left part of the machine. The machine uses Casmate and Enroute for importing files, but it's control software is a custom made software that accepts only *.PLT files. The machine basically works like a 2D plotter. You only adjust the cutting speed and depth. Like I said, rpm is adjusted manually on the machine, which sucks.
People say it's a sturdy build machine, I agree. Other than that, the limit switches aren't working and it's easy to loose the "Starting Point". There's no cooling for the cutting blade (I don't know the correct name for it) and no suction for the shavings. And the worst part is that I can't run the machine on a operation system newer than Windows 98. There are no drivers for Windows XP. Yet I didn't contact the manufacturer in China yet.
So what do you think about the machine? Anybody used or heard of this brand before?
LinkBack URL
About LinkBacks
However I did a short research on the net. Mach3 is a Control Software and it's price in Turkey is 175 USD. I'll probably have to buy a new PC too for Mach3 to work. You won't believe on what kind of junk I'm running the CNC Router. So say 500+ USD for that new PC too. Smooth Stepper's price is 155$ online for USA.
