Results 1 to 3 of 3
Thread: most similar controller for Chinese machine
    Joa
    Joa is offline
    Feb 2005
    Which commonly used controllers (Fanuc, etc.) are most similar in processing (G-code library, etc) to the DSP controllers that come on the Chinese machines?
    Joa
    Joa is offline
    Feb 2005
    Ok, I'll try to rephrase...
    Who is using a DSP controller with their machine and what CAM software are you using?
    Aug 2011
    Vectric Aspire or any of the Vecrtic software is well suited and outputs .tap format.
    I you f enable f code on Dsp which gives feed rate control to suit your applied tooling
  1. Who has syntec controller running there chinese atc
    By simso in forum Chinese Machines
    Last Post: 10-22-2011, 09:47 AM
  2. Chinese RZNC-05 controller & spindle help?
    By Metalmog in forum Commercial CNC Wood Routers
    Last Post: 05-25-2010, 12:20 AM
  3. Replies: 0
    Last Post: 05-21-2010, 02:34 AM
  4. Newbie- Which machine? cnc-step or similar?
    By Ohlsson in forum Commercial CNC Wood Routers
    Last Post: 11-26-2009, 06:57 AM
  5. New Machine Build- Cheap Chinese Controller
    By Arkwhizzard in forum Controller Cards
    Last Post: 02-27-2009, 04:07 AM
