Results 1 to 5 of 5
Thread: Problems with 3040 steppers
    Feb 2012
    Norway
    Question Problems with 3040 steppers
    Hello everyone,
    I recently received a 3040 cnc from ebay, and have installed the newest mach3 and configured with the settings from the manual. The Z-axis is working perfectly, but then again, I kind of hoped for more than a one axis machine :P
    Both the z-axis and the y-axis moves randomly to one of the two directions, even though I keep pressing the positive direction in mach3. Sometimes, it even just jerks forward and back a little and make a lot of noise, so something is definitely wrong. I am thinking the stepper driver boards, but it would be weird for both the X and Y axis boards to be faulty, but the Z axis board working perfectly?
    I tried searching for others with the same problem, but seems there aren't a lot of people having trouble with steppers randomly deciding their own directions. As a long time forum lurker, but first time poster, I hope some of you with more experience can help me out, as I am really eager to start this new hobby.
    Thanks in advance for any answers!
    - Tonnes
    Oct 2011
    Espaņa
    Hello,
    I have a cnc 6040 with the same problem as you. The Z axis goes "crazy" although I press Z + + or Z--. I changed the engine and the Z axis position is wrong with all engines. The Y axis and the X axis work well.
    I think it may be the wiring, one wiring has broken (have 4 per motor) and so the engine does what it wants.
    I've also tried to change the engine controller cards and always makes the wrong move the Z axis (so it is not hardware problem).
    Tomorrow finds itself comes to intensity stepper motor in the 4 inputs of stepper motors.
    Best regards and excuse my bad English.
    Feb 2012
    China
    the problem is the wire,
    i don't understand what you said the z-axis and the y-axis moves randomly to one of the two directions,in basic,the z and y axis cann't move in the same direction.
    Feb 2012
    China
    you can replace the wire of X axis and Y
    Registered port_huon's Avatar
    Dec 2007
    Have you tried swapping cables, motors between the different axes to see if the problem is the motor, driver or cable?
    I had a similar problem with my 6040 and swapping things around proved it to be a faulty driver board.
    NOTE: Be sure to turn the power off before swapping things!
    Regards
    Geoff
    1. Newbie- 3040 cncdiy running problems
      By dantheman83 in forum Benchtop Machines
      Last Post: 05-12-2013, 05:37 PM
    2. Anyone still running a Makino EC-3040????
      By Helix60 in forum General Waterjet
      Last Post: 07-07-2010, 08:24 AM
    3. Will these steppers cause any problems
      By Rift in forum Taig Mills & Lathes
      Last Post: 05-12-2010, 04:15 AM
    4. How to fix table on HX 3040
      By chameleoncav in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 01-10-2010, 11:40 AM
    5. New HX 3040 owner
      Last Post: 10-01-2009, 09:45 AM
