Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines
Chinese Machines Discuss Chinese machine here!
Old 01-24-2012, 10:43 PM
saratbabu is on a distinguished road
dual spindles operating.
Hi,Everybody.
1.I have Chiniese Router,which is 1530 Model,dual spindles.I have few doubts on it.
How we can operate 2 spindles at once?
How we can set the 2 Origins with 2 spindles?
Please give me suggeions.
2.I have Another CNC Router which is 3 axis,stepper with YAKO 2811MA drivers.Operating is NC Studio.
I need to change the operating from NC STUDIO to DSP.
How can i change it?
Old 05-05-2012, 11:02 AM
ajaydevb is on a distinguished road
Regarding your 1st query, normal version of NCSTUDIO cannot zero or set origin individually. You have to use their V8 Double Spindle Version. There is a three spindle version also.Please check it.
Regarding your 2nd query, I am not confident in saying that you can't set individual origin for both the spindles.
But there is hard path to work without having the above said software. First set the 1st part and set origin.Then set the 2nd workpiece to touch the tip of the tool and then clamp to the table. This method is only applicable if both the spindles are mounted on a single Z axis plate. If they are on separate Z plates, you have to use the Double spindle version.
Contact me at ajaydevb@gmail.com ( +91 9966688111).
Newbie- Dual 5 hp spindles ceencee Phase Converters and VFD 6 06-02-2011 06:47 PM
Emco 420 going threw the cog belt that drives the dual main spindles, every month. ameyer EMCO Lathe 0 04-18-2011 06:11 PM
Any reasonably priced (cheap) spindles other than the chinese spindles? HereinCS DIY-CNC Router Table Machines 7 07-30-2010 11:58 AM
Spindles de alta qualidade.High quality spindles. Newtron Product Announcements & Manufacturer News 0 09-21-2009 02:33 PM
Good article on dual contact spindles/toolholders Belding General Metalwork Discussion 1 11-11-2008 03:27 AM
