| Chinese Machines Discuss Chinese machine here! |
| Hi, this is Ally from Jinan Quick CNC Router Co., Ltd. Here is the information of cnc machine K6100A as follows: Model K6100A X-Y-Z axis working area 600 x1,000 x 120mm Machine size 1,300 x 1,700mm Resolutions 0.025mm X-Y-Z movement Ball screw drive/Germany Max. speed 10,000mm/min Max. cutting speed 6,000mm/min Spindle 1.5kw/ water cooling spindle Spindle speed 24,000rpm Inverter power 1.5kw Drive motors stepper Working voltage AC220V/50-60Hz Command code G code Computer interface USB 2.2 Collet ER11 -6mm,3.175mm Software Type3 Software/France Controls DSP0401 (Digital Signal Processor) Packing dimensions 1325 x1750 x 1800 mm,350 kgs Equipment available Auto cut adjusting device This is the best selling line. If you like this machine, pls let me know. Skype: allyquick Jinan Quick CNC Router Co., Ltd. Ally |
| Hi I'm new, I feel fortunate to have found this forum where many real users express their experiences, well I tell them I want to buy a small cnc, but my job is in metals like copper, bronze, iron and steel. So I guess the spindle motor must be powerful and the gantry has to be resistant Someone who can help me to configure parts of the machine for metal engraving. Thank you very much. Luis |
| Hi, Yes, if you want to engrave aluminum, bronze and iron, you need to use big power spindle, and the gantry will be more stronger to support the spindle. If you want small machine, I'd like to recommend you to consider model K6100A with working area: 600mm*1000mm and model K1212 with working area: 1200mm*1200mm, with 3KW or 4.5KW spindle. Ally Skype: allyquick MSN: quickcnc011@hotmail.com Mobile: 86-15069190790 |
| Thanks for your answer, I would like to know the resolution and detail of engraving on metal, cnc machine K6100A I want to work 8 hours a day, and my question is whether it is designed for such requirements, I hope your recommendation profecional. Thanks |
| [QUOTE=Peruanzon;1077397]Thanks for your answer, I would like to know the resolution and detail of engraving on metal, cnc machine K6100A I want to work 8 hours a day, and my question is whether it is designed for such requirements, I hope your recommendation profecional. Hi, If you want to engrave on aluminium, cnc machine K6100A with 3KW or 4.5KW spindle is ok. You need to make the revolving speed down a bit and choose the special tool for engraving metal. When you engrave on the aluminium, you should engrave a little thickness each step. I think it is ok if you work 8 hours a day, but you'd better not to make the machine always working 8 hours for long time. Ally Skype ID: allyquick Email: quickcnc011@hotmail.com |
| Tags |
| cnc advertising machine, cnc woodworking machine, mini cnc machine |
| Quick CNC K6100a for a kiwi... | kiwichris | Chinese Machines | 98 | 01-31-2012 12:56 AM |
| Distinction between laser engraving between special LGP engraving machine when produ | CUTCNC | Laser Engraving & Cutting Machines | 0 | 11-21-2011 02:46 AM |
| Martys K6100A Adventure | Marty989 | Australia, New Zealand Club house | 18 | 09-14-2011 06:25 AM |
| Reading Spindle RPM - Quick K6100A | SkipW | Chinese Machines | 3 | 02-08-2011 10:57 AM |
| K6100A Table Mod | SkipW | Chinese Machines | 1 | 10-20-2010 06:53 PM |
