i have the same problem
have you solve it?
if yes how?
Hello every one.
I am new in this forum, and I need some help.
I get a new cnc machine ts-3040c-h80 yesterday, but I can not get it
work, I am using a IBM Thinkpad T51 and running mach 3, but I have tried
to set port and pins as it is shown in the manual, but nothing happens.
Do some one have this machine and how have you set up the port and pins?
Maybe the IBM can give enough power?
Please help!
Yours sincerely
Kjeld Ottsen
have you solve it?
if yes how?
Hey
I also bought this mashine, and got problems.
When i received it, i found that the pcb mounted at the parallel port had a short. Due to bad ingineering.
The seller ( Amonstar Inc ) send me a replecement board, and now the box
powers up. ( Fan is running, and the led's at the driverboards are on ).
When i install Mach3, and runs it out of the box, i can get it moving, but in
one direction only. It sounds like it's trying to move the z-direction further
down at the same time.
When i follow the instructions in the manual, and setup the pins, the same
happens.
Then i install the configuration files from the manufacturer, i get into deeper s...
In Mach3, the resetbutton gets green, somtimes gray, and the text in it dissapeers. When i turn the machine on, i cant move anything.
I have given up on Amonstar, communicating with them is mostly 'black talk', just like the manual. Its a disaster.
Hello Karsten
I got a file from another user, and this solve my problem and it is running very fine now.
Kjeld
PM mail sendt til dig ;-)
Hello,
I am considerring to buy the same machine. I am makin small articles from wood e.g. jewelery boxes, vehicle models, toys etc.
is this machine suitable for that sort of work or is it to small?
John L
Dear friends,
Anyone have a good configuration file for TS-3040C-H80?
I am new...
Best Regards
Luis
Here is the file for this cnc machine.
TS-3040C backup settings for mach3mill.rar
bonjour à tous
j'ai le meme probleme, mais avec l'axe X qui marche que dans un seul sens
axes y et z ok
Pouvez vous m'aider ? merci
Did you get it working?
I initially could not reset the machile until I swapped the EMERGENCY STOP input to active LOW----then I had control.
I have just received my machine------it was not fully assembled so I had to put the cables on the Servo motors etc. Also the base bracket was bent, and some screws loose. I have fixed it all but my base table is not parallel with the X/Y movement of the gantry. It is about 1-2 m higher on one side. I don't know if the original bent bracket caused this, but in any case it needs to be fixed before I can do any proper milling/engraving
Does anyone know if the base table-gantry alignment can be adjusted mechanically? If not, is there a way I can add the correction to Mach3? Or make a G code correction or something?
