| Chinese Machines Discuss Chinese machine here! |
I've got a China router with YooCNC step/dir driver boards and I've bought a Usb controller card from Planet CNC which I'm going to wire to the YooCNC driver boards. I don't have any good documentation on the YooCNC so I'm a bit unsure on how to wire it to the USB controller. Anyone who have done this? Or anyone who can help me with this? Here's how I've wired it: ![]() Thanks |
| I do not have either of those boards, however I will see if I can help you get the proper board to board connections. The Planet CNC connector is supposed to follow the Pminmo 10-pin IDC connector standard described at: DIY Interface Technical Information My interpretation of the signal labels on the YooCNC driver is that CP+ and CP- are step (clock) pulse inputs to an optoisolator; EN+ and EN- are enable inputs to another optoisolator; and there should probably be two additional inputs, for the Direction signal going to another optoisolator, possibly labeled CW+ and CW- (or maybe labeled DIR+ and DIR-). Can you verify that you have those additional input pins on your driver? In your diagram it appears that you have the DIR output from the Planet CNC board going to an enable input of the driver instead of going to a direction input. If that is the case, then it will not work properly as wired. Let me know whether you have located those additional direction signal pins, and if so, I can continue with my recommendation. |
| There are only 4 wires from the YooCNC and they are labeled CP+ CP- EN+ EN- There are however 2 soldering points on the board labeled DIR+ DIR- (they are not connected) On the original controller board the 4 wires are labeled PU+ PU- DIR+ DIR- DIR+ goes to EN+ on the driver board DIR- goes to EN- PU+ goes to CP+ on the driver board PU- goes to CP- |
So, I can't give any more advice other than to give it a try. There are some unknowns here - the primary one being whether your USB board's + outputs have sufficient current sourcing capability to drive the optoisolator LED inputs in your driver (which I am guessing are present). If it is set up like other drivers with which I am familiar, then there are two ways of hooking up your USB controller to the driver. One way would be like your diagram above, namely, where the controller signals source current which directly turns on the LEDs in the optoisolator inputs. The other hookup would have you wire a small value pull-up resistor (perhaps using a resistance in the range of a few hundred ohms) between each of the + inputs and the +5 volt power supply terminal, and then hook up the step and direction outputs from your controller to the corresponding - (minus) inputs of the driver. In that case, the LEDs in the driver's optoisolators are turned on by an active-low signal coming from your controller. So if you can't get it working the way that your diagram shows, then you have the option of trying the alternative hookup using the pull-up resistors. |
| going by the last diagram it looks like the direction inputs ard wrongly labled as enable I would connect the new driver as in the diagram below John PS very often logic IC's at logic 0 can sink more current than source when at a logic 1 (as in your first diagram) |
| Don't know it this matter but the YooCNC driver card har it's own power. Here's acouple of pictures of the driver board and the old controller board (YooCNC) ![]() |
| looking at the photo's on the yoocnc b.o.b , the pcb tracks for the "A" axis you can see the pu+ and dir+ connections go to the +5v supply from the board taking the white , yellow blue and red wire connecting the yoocbc driver to be the same wires I would now expect its the red and yellow wires that are connected to +5V (you can check this with a multimeter) the blue the step pulse and white the direction control if you look closely at the holes marked dir+ and dir- on driver the you can see two fine track going to the connector John PS looking at the stepper driver you have two EL817 opto isolators and a 6N137 I'd expect the EL817's to for be step and direction (blue & white wires) and the 6N137 for an enable input ( connect the yellow wire to 0V to disable the drive) the three resistors R11,R12 and R13 to be all connected to +5V ( red wire) Last edited by john_100; 09-10-2011 at 06:01 PM. |
#10
| I think with in mach3 you can switch between positive and negative going pulses (I've not used mach 3 ,I'll have to read the book again !) either way , look at the direction output you should see it switch as you change direction do you have the E-stop pins connected ? John |
#12
| yes thats what I expect at the driver board I assume there is another three unused connections on the board that are hidden from view by the 4 pin connector ( PU+ , PU- and EN + ) on other stepper drivers the drive is disabled when the LED in the opto isolator is energised ! and is not connected when it's not being used with the yoocnc bob both terminals are connected to +5v , there for the motor is enabled John Last edited by john_100; 09-11-2011 at 07:49 AM. Reason: add diagram |
| x2 cnc conversion | pac1969 | Australia, New Zealand Club house | 0 | 10-12-2009 05:32 AM |
| Need Help With Conversion | NSCCstudent | Emco Mills | 3 | 10-02-2009 05:41 PM |
| Need Help!- Conversion Please! | kawazuki | Solidworks | 2 | 06-25-2009 01:56 PM |
| servo conversion vs stepper conversion | contractdesign | Bridgeport and Hardinge Mills | 3 | 07-26-2008 02:54 PM |
| Has any one done a CNC X1 conversion | cweeks | Benchtop Machines | 4 | 11-11-2006 10:08 AM |
