Results 1 to 2 of 2
Thread: SUBA CNC Machine (Sunfar E300) Problem
    Sep 2011
    Oman
    My company recently modified a SUBA CNC Machine with a BZT Controller and an Axemotion PulseBox from Ironwood Co. based in France . We reused the Leadshine Modules and Sunfar Inverter (E300-2S0015L). The X,Y, and Z motion is already working.
    My main problem is for the Spindle motion. The inverter is not providing an output supply for my spindle motor. But when I try to activate the spindle the external control display indicates RUN but there is no voltage reading. The input supply is OK.
    Please Advice.
    Thanks.
    A Newbie with CNC machines.
    Nov 2010
    jfbacomo,
    I have to assume a couple of things...
    1: The inverter was working before.
    2: Your inverter was wired for inputs from the controller to turn it on and off.
    Check to see if there are wires connected to screw terminals X1, X2, and X3 on your inverter. Those are the inputs for your 5v signals coming from your controller to set the speeds on your inverter.
    If it is wired like mine was, different combinations of those will give you different spindle speeds.
    Make sure you have X1, X2, and X3 connected to outputs from your controller and that you can turn on and off any of the outputs in any combination.
    Hope this helps.
    From Wikipedia - "..butter knife..any table knife designed with a dull edge and rounded point". I've never claimed to be the sharpest knife in the drawer!
  1. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 10:51 AM
  2. G540 and Sunfar VFD
    By WillyInAus in forum Gecko Drives
    Last Post: 07-20-2009, 12:10 AM
  3. Need Help!- Problem with Solsylva DIY Machine
    By mlammert in forum DIY CNC Router Table Machines
    Last Post: 07-09-2008, 07:11 AM
  4. New machine problem !! many questionsss
    By mindstorm88 in forum DIY CNC Router Table Machines
    Last Post: 08-11-2006, 07:29 PM
  5. Gantry Machine Problem
    By Alex S.A in forum General Metalwork Discussion
    Last Post: 09-02-2005, 02:36 PM
