| Chinese Machines Discuss Chinese machine here! |
Hi All I am extremely new to world of CNC. We have just recieved our machine from Quick CNC the machine is set up with a Syntec controller, Manuel Tool Change with a auto touch off tool sensor. We will be using V carve pro. In v carve/aspire the installed post processors for syntec are for auto tool change machines, and we are confused how a manual tool change would be specified in the post processor. We prefer not to have seperate toolpath files for each tool used in a job. Is there any information on how manual tool changers are done between toolpaths in 1 file? In lay terms, we would like the machine to run the tool path with the first tool then return home, wait whilst we perform a manual tool change then on the press of a "continue button", the tool sensing will commence and continue with the next tool path in the file. It appears this may of been done with the "shop bot machine" but not real sure??? Any help would be great Thanks Anthony |
Hi, Use the the standard output for an automatic tool change. Ex. T0101 It will not interfer with the machining as you will have the tool offsets for each tool in the output. You will need to have an "M05" to stop the spindle after each operation is completed and the clearance for the tool is reached, EX. X1.100 Z.100. If you are using "G96" constant surface speed, put the "M05" as the line following the "G97" line. Then put the "M00" as the line following your home position line, EX. G30 U0W0. The machine will now wait for you to press the auto button. This is when you can safely manualy change tools. You must be careful of course to be using the correct tool for each of the subsequent operations. Note: At the beginning of each tool, The "G97" must be used on the line prior to the "G50" maximum RPM line and the "G96" must follow both of these lines usually just after the tool is in the start cutting position, EX. X1.100 Z.100. I use GibbsCAM and there is a Ganesh 4012 lathe post available. If using a tailstock, remove any "W0" in the program. ![]() % O1( GANESH POST OUTPUT.NCF ) ( FORMAT: SYNTEC 4012 GANESH GT1628 [BA] L3650.85.1.PST ) ( 3/31/2012 AT 1:31 PM ) ( OUTPUT IN ABSOLUTE INCHES ) ( T1 = ) ( T2 = ) ( T3 = ) ( OPERATION 1: ROUGH ) ( WORKGROUP ) ( TOOL 1: 0.03125 RAD. 80-DEG. DIAMOND ) N1G30U0W0 G54 G0G40T0101 G97S1500M3 G50S1500 G0X2.1Z.1 Z.105 M8 G1X2.F.01 G96S1000 G0X1.9 G1Z-1.3023F.012 G3X1.91Z-1.3312R.0862 G1Z-3.8843 X2. G0Z.105 X1.8 G1Z-1.2509 G3X1.9Z-1.3023R.0862 G0Z.105 X1.7 G1Z-1.2362 X1.7095Z-1.241 G2X1.7289Z-1.245R.0138 G1X1.7375 G3X1.8Z-1.2509R.0862 G0Z.105 X1.6 G1Z-1.1862 X1.7Z-1.2362 G0Z.105 X1.5 G1Z-1.1362 X1.6Z-1.1862 G0Z.105 X1.4 G1Z-1.0862 X1.5Z-1.1362 G0Z.105 X1.3 G1Z-1.0362 X1.4Z-1.0862 G0Z.105 X1.2 G1Z-.9862 X1.3Z-1.0362 G0Z.105 X1.1 G1Z-.9362 X1.2Z-.9862 G0Z.105 X1. G1Z-.8862 X1.1Z-.9362 G0Z.105 X.9 G1Z-.8362 X1.Z-.8862 G0Z.105 X.8 G1Z-.7862 X.9Z-.8362 G0Z.105 X.7 G1Z-.5159 G3X.76Z-.5812R.0862 G1Z-.7605 G2X.7681Z-.7703R.0138 G1X.8Z-.7862 G0Z.105 X.6 G1Z-.4952 G3X.7Z-.5159R.0862 G0Z.105 X.5 G1Z-.3023 G3X.51Z-.3313R.0862 G1Z-.4813 G2X.5375Z-.495R.0138 G1X.5875 X.6Z-.4952 G0Z.105 X.4 G1Z-.2509 G3X.5Z-.3023R.0862 G0Z.105 X.3 G1Z-.245 X.3375 G3X.4Z-.2509R.0862 G0Z.105 X.2 G1Z-.0159 G3X.26Z-.0813R.0862 G1Z-.2312 G2X.2875Z-.245R.0138 G1X.3 G0Z.105 X.1 G1Z.0048 G3X.2Z-.0159R.0862 G0Z.105 X.0078 G1Z.005 X.0875 X.1Z.0048 G0X2.1 Z.1 G97S1500 M05 G30U0W0 M0 ( OPERATION 2: CONTOUR ) ( WORKGROUP ) ( TOOL 2: 0.03125 RAD. 80-DEG. DIAMOND ) N2G30U0W0 G54 G0G40T0202 G97S1500M3 G50S1500 G0X2.1Z.1 Z.075 M8 X0. G1X-.1125F.01 G96S500 Z.025 G2X-.0625Z0.R.025 G1X.0875F.005 G3X.25Z-.0812R.0813 G1Z-.2313 G2X.2875Z-.25R.0188 G1X.3375 G3X.5Z-.3313R.0813 G1Z-.4813 G2X.5375Z-.5R.0188 G1X.5875 G3X.75Z-.5812R.0813 G1Z-.7605 G2X.761Z-.7738R.0188 G1X1.7024Z-1.2445 G2X1.7289Z-1.25R.0188 G1X1.7375 G3X1.9Z-1.3312R.0813 G1Z-3.8659 G2X1.95Z-3.8909R.025 G1X2.05 G0X2.1 Z.1 G97S909 M05 G30U0W0 M0 ( OPERATION 3: THREAD ) ( WORKGROUP ) ( TOOL 3: 0 RAD. THREADING - GROOVE STYLE ) N3G30U0W0 G54 G0G40T0303 G97S1000M3 G0X2.1361Z.1718 Z.1 M8 X.3861 G1X.35F.0769 G0X.4256 G32Z-.2F.0769 G0X.35 Z.1 X.4056 G32Z-.2F.0769 G0X2.1361 Z.1718 M9 M05 G30U0W0 M30 % ( FILE LENGTH - 2319 CHARACTERS ) ( FILE LENGTH - 19.62 FEET ) ( FILE LENGTH - 6.06 METERS ) |
| help with PP for Syntec Manuela tool change | redvanth | Post Processors | 0 | 08-27-2011 07:20 AM |
| Post processor for Syntec 900 T Controller? | weaston | Post Processor Files | 4 | 03-17-2011 01:06 AM |
| Need Help!- manual tool change m2 control | metlshpr | Mazak, Mitsubishi, Mazatrol | 2 | 02-10-2009 06:58 PM |
| Manual Tool Change | ChimpChamp | Mastercam | 2 | 12-17-2007 07:25 AM |
| Manual Automatic Tool Change | ynneb | DIY-CNC Router Table Machines | 2 | 09-29-2004 12:21 PM |
