| Chinese Machines Discuss Chinese machine here! |
Hi All, A few notes about my J-cut 6090A router rebuild. I’m new to this CNC world but I have been designing & building all types of machines for years. After I received my 6090 I read a lot of posts on this site about it, mainly about its construction. So... First I took off the sides & welded bars under the table to support the water cooling tank & power converter. Next I put it on wheels to move it around more easily and then added threaded posts with feet to stabilize it when I get it in position. I then removed the black padding from the table top, unscrewed the aluminum rails & installed a ¼” x 49” x 29¼” sheet of steel. I replaced the rails & added 2 new 40mm rails on each side drilling& tapping around 100 holes. I now have 0 flex on the top. Next I looked at the limit switches (ha ha) the factory said that I have 600mm-x & 900mm-y by removing the Micro switches & replacing them with proximity sensors on both ends of travel I now have 686x & 935y. I then add another proximity sensor to the x & y 2mm in from the dead stops triggering led lights to verify my 0x, 0y start point. I also added a small n/c switch on each assess so when I do reach the end of travel I just hold the switch & walk it back into range without having to power down & lose my reference point. I added a second emergency stop switch to the other side of the machine. I installed a power control box where the pump lights & other accessories can be controlled. I made a tool touch block gage to set my z. Last I added 2 small lights on the motor. I’m working on a dust collection unit – but first I need to make some dust. Next I’m debating on tearing out the motors & control card? Let me know if you guys have any other ideas? |
| JCUT 6090A or JCUT 6090B | Butterknife | Chinese Machines | 79 | 04-13-2012 06:22 AM |
| Jcut 6090a Setup instructions | wethecom | General Full 3D Wood Router Machines | 4 | 03-31-2012 02:44 AM |
| JCUT-6090A vs SHM0609 vs SK-7090F/S | tew | Chinese Machines | 28 | 08-18-2011 04:37 AM |
| I CAN,T START WORKING WITH THE JCUT 6090A . HELP !!! | javieronandia | Engraving Machines | 21 | 04-04-2011 07:03 PM |
| rebuild | corrie | CNC Wood Router Project Log | 5 | 03-20-2008 04:29 PM |
