Results 1 to 7 of 7
Thread: how to change my DSP language ?
    Apr 2011
    Iran
    Hi there
    I've got a RZNC 0504 DSP controller, but everything is in Chinese and I cannot follow the menu to change the language !
    I have downloaded the English Menu to the DSP by DSP 0501 Program , but I cannot change it from the Joystick's Menu ( cause I cannot read Chinese )
    I will appreciate any help !
    Feb 2005
    Here is a youtube video that shows you how to change the DSP language.
    [nomedia="http://www.youtube.com/watch?v=CG-xrCJ9Ab8"]YouTube - ‪How to change language to English on DSP control panel‬‏[/nomedia]
    Hope it works for you.
    Sep 2008
    P.R.C
    Hi Hamed:
    Since you have downloaded the English label and menu files, you can change the languag as following steps: when it shows when you supply power, then press "Delete"(DON’T GO HOME)--"Menu"(ENTER MENU)-"5" button twice(MOVE THE CURSOR TO THE 3RD ITEM)—“OK"(ENTER THE SETTING)--"OK"(LANGUAGE SETTING)--"5"--"OK" then it changes into English.
    Because there are different version of English label and menu files, so when it changes into english, you need to have a check whether the files are right or not. if they are right, the showing message are right, otherwise, it shows unrecognized characters.
    Good luck!
    Alan
    Apr 2011
    Iran
    Quote Originally Posted by king9558 View Post
    Hi Hamed:
    Good luck!
    Alan
    thanks alan , I've tired it and it worked well !
    Apr 2011
    Iran
    Quote Originally Posted by SkipW View Post
    Thanks alot SkipW, It worked!
    Jun 2009
    China
    Quote Originally Posted by Hamed View Post
    Hi there
    hello Hamad,
    you write me an email and I will send you a video for change DSP language from Chinese to English.
    And one of our engineer will be in Terhran early July for machine training, you please feel free to contact us if you need any help
    Best regards
    Roctech
    CNC Router ATC|CNC cutting machines|CNC router machine Manufacturer-RocTech
    Jun 2009
    China
    Quote Originally Posted by roctech View Post
    hello Hamad,
    Best regards
    Roctech
    Hi Hamad,
    I am sorry, I didn't see you already settled the problem, but welcome to ask other questions.
    Good luck
    Roctech
    1. change language of fanuc 6m
      By mohammad reza in forum Fanuc
      Last Post: 11-09-2009, 09:18 AM
    2. Change language of 21i-m
      By fomaz in forum Fanuc
      Last Post: 10-03-2009, 02:14 AM
    3. Need Help!- Mo Language change
      By greenery_fr in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 05-29-2009, 07:15 AM
    4. language change on meldas 65-M
      By scale in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 12-23-2008, 04:22 AM
    5. Need Help!- Language change on Mazatrol Cam T2
      By andreypav in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 02-13-2008, 09:23 PM
