Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines
Chinese Machines Discuss Chinese machine here!
Old 02-13-2011, 05:47 PM
7of9 is on a distinguished road
Spindle speed via dsp??
I own a chinese built cnc router. It is equipped with an 3,2kw spindle, a dsp controller an a spindle inverter.
At the moment my dsp and the inverter are ignoring the s-controller data to control the spindle rotation speed.
Is there any possibility to get the spindle controlled by software/dsp?
thx in advance
best
Kai
Old 02-13-2011, 08:17 PM
SkipW is on a distinguished road
Hi Kai,
I asked that same question not too long ago and I was told "the DSP controller does not support S codes, for S code it needs analog signal, while the dsp does not have, it only gets digital signals."
Hope that helps.
Old 02-14-2011, 02:55 AM
Originally Posted by SkipW View Post
Hi Kai,
Hope that helps.
wow - this would be a big disadvantage! But...
The Inverter needs analog signals ok - but isnt there any possibility to transform the digital output from the dsp into an analog signal for the inverter?
For me it sounds not impossible - but without having any idea how to manage.
Perhaps there is somebody outthere who "invented" a workaround to manage it?!
best
Kai
Old 02-14-2011, 04:01 AM
rocket67 is on a distinguished road
Check out the Thread in this link
http://www.cnczone.com/forums/excite..._excitech.html
Look in particular to Taney`s post ( no.9 ). Might help you.
There is also a link to an English language DSP manual on the Excitech Threads.
Rocket.
Old 02-14-2011, 06:07 AM
Rocket.
Hi Rocket,
thx for the link, but after reading the thrad i am as confused as before...
I heard the statement very often that the dsp is not able to control the spindle/inverter.
There are two things wich make me think that there should be a possibility:
My dsp displays the spindle speed and there is a point in the menu
Proc Spd 3000.00
Trvl Spd 3000.00
ZDown Rat 1.00
Spd Rati 1.00
Spd Grad 6
X Axis: 400.00
Y Axis: 200.00
Z Axis: 400.00
A Up mm 100.00
Drilllval 1.00
wich in my understanding is responsible for the spindle - isnt it?
Still confused and hoping
Kai
Old 05-17-2011, 04:28 AM
king9558 is on a distinguished road
Hi Kai:
the dsp controller supports most G codes, M codes and F code. but it does not support S codes in the g code files. And the Dsp controller company has no plan to make such function controller.
Alan
sx3 Spindle Speed rwskinner Benchtop Machines 6 01-15-2011 06:10 PM
Newbie- Spindle Speed ngwanhoe General Metalwork Discussion 2 10-31-2010 08:02 PM
No low spindle speed shoeman Bridgeport/Romi Lathes 1 04-06-2010 07:51 AM
Spindle Speed mikemill General CNC (Mill and Lathe) Control Software (NC) 0 01-04-2008 10:09 AM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
