Results 1 to 3 of 3
Thread: SUDA ST1212S CNC ROUTER HELP!!
    Jan 2011
    I just imported a Suda ST1212S CNC Router from China to Australia.
    I need help with the installation / setup of the machine and program.
    I got optional extras including vacuum bed, dust collection, spindle cooling system, servo motor.
    the package did not come with instructions to setup the machine. some of the cords are basic and easy to assemble.
    i am having trouble with the vacuum assembly.
    i also am having trouble with setting up the port on the computer to transfer from TYPE 3 Software to the DSP Controller via the USB cable (printer cable)
    i also need to know how to set the point of origon. currently it is on the bottom left which is fine, however it seems to be off the machine vacuum bed ( not at the correct position x-0 y-0 )
    if someone could help me that would be excellent!!
    THANX!
    Sep 2008
    P.R.C
    hi:
    i am Alan, I have worked for years in the dsp company, so i think i can help if you are still in troulbe.
    pls add my messenger: king9558@msn.com
    Regards
    Alan
    Jul 2012
    Uruguay
    I myself got a SUDA a few weeks ago and I'm struggling with it. Please see if you cna help me with my post and perhaps we can help each other. I'm an electronic engineer and I must make this thing work :P
  1. Problem- SUDA CNC MACHINE ELECTRONICS DONT WORK
    By CECILIO in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 09-10-2012, 12:59 AM
  2. SUDA SL9060 with MPC03
    By buddhafragt in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 08-25-2011, 04:53 AM
  3. which company is better than others? SUDA,FANCH,Ruijie,Excitech
    By kharazmi in forum Want To Buy...Need help!
    Last Post: 05-17-2011, 10:14 AM
  4. Need Help!- Bearing Failure on SUDA SD1208
    By joeyg in forum Commercial CNC Wood Routers
    Last Post: 07-02-2009, 05:43 PM
  5. Need Help!- Cooling liquid for SUDA SD1208?
    Last Post: 12-29-2008, 07:56 AM
