Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines
Chinese Machines Discuss Chinese machine here!
Old 12-31-2010, 06:56 AM
mecanicu is on a distinguished road
Post Looking for info on ATC upgrade
I'm looking for info from excitech atc cnc owners i need to know the spindle and vfd inverter parameters.
Now i have a Delta VFD-B class inverter and HSD 6.5Kw spindle(italy, no atc). And i wanna upgrade to a 7.5Kw HSD spindle (atc system) but i don't know if my VFD will work. The VFD i have can handle 7.5Kw but the max. output frequency is 400Hz and all the HSD spindle (atc system) ar working at 800Hz.
If someone has a ideea pleas share
Old 05-19-2011, 05:03 AM
king9558 is on a distinguished road
Hi Mecanicu:
pls check your delta inverter's version. Maybe you are going to change HSD ESE929 and it has a 4 poles motor, and you'd better ran it 24000rpm, 12000rpm is not good. for the delta inverter(VFD-B) have different version, some can change to 800hz, some cannot, and all their default value is 400hz.
check it and send me an email: king9558@msn.com. if it is the right version, i tell you how to change the parameters.
Regards
Alan
New to CNC, looking to upgrade Gothover Want To Buy...Need help! 0 10-26-2010 06:13 PM
Upgrade?? samu Fanuc 5 01-06-2009 07:24 PM
Control Upgrade Info don de MultiTEK CNC Controllers 1 01-22-2007 12:25 PM
upgrade bbrreid General Metal Working Machines 1 02-03-2006 03:10 PM
upgrade Rudee Fadal 4 01-29-2004 09:19 AM
