Results 1 to 6 of 6
Thread: help
    Nov 2007
    egypt
    help
    i hvae problem with artcam and my china machin when i make vcarve program the machin give me bad vcarve and deeb
    my machin control yako yka2811ma
    Attached Files Attached Files
    Nov 2007
    egypt
    why
    no evry body khow to helb me
    Registered neilw20's Avatar
    Jun 2007
    Looks like backlash. Check with a dial indicator.
    Don't fix it with Mach3. Fix the mechanical problem.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Feb 2005
    Or maybe your machine doesn't like the post processor your are using in Artcam to make the G-code. Have you tried the Gcode_mm_arc post? Which one are you using?
    Nov 2007
    egypt
    iuseing postprosser lang[mm] [*.cnc]
    Feb 2005
    Was that post processor recommended by the machine manufacturer?
    I would try the Gcode_mm_arc post. Try it on a test piece to see if it works better.
    Skip
  • Posting Permissions
