Hi Everyone,
My name is Luke Kirkwood of Montreal Canada and I purchased a Jinan Jindiao Technology Co., Ltd Laser Cutter and Engraving Machine just last week.
I purchased the JD90120 with both a 60W head and 180W head. I had the machine working area width increased to 1300 mm so I can work on 4' wide panels. Because there is 2x cutting heads, you also reduce your working area as the heads are offset from centre. The 1300 mm wide working area should be perfect for 4' panels.
My contact person was Lisa and she also helped me with organizing other products supplied by other companies to be packed with the laser shipment.
Lisa advised me it will be 20-25 days assembly and 20 days on water to the Port of Montreal.
I will keep you all up to date with the shipping, setup and operation of the JD90120 machine. I plan to have a smooth relationship with JDCutters with excellent post sales support so I will provide accurate and true information regarding Jinan Jindiao Technology Co., Ltd.
I look forward to you all following my JD90120 product review.
Cheers
Luke Kirkwood
luke@duform.com
+1 514 663 9304
LinkBack URL
About LinkBacks
