Results 1 to 4 of 4
Thread: DSP controler RZNC-05 advise
    6bx
    6bx is offline
    Feb 2009
    Cyprus
    Question DSP controler RZNC-05 advise
    I am intent to buy a DSP controler for my chinese cnc router and i have download the manual to study it.I have found on the manual that i have to configure the technical part (Machine set up)of the controler such as:
    Pulse Equivalent
    Voltage setup
    Output Pulse
    How i determine this values?
    Also there is a wiring diagram reagarding the board and it shows two(2) power supply, 24v and the other unknown output voltage.The question is if the existin power supply wich came with the router 48V it will power the motors and drivers,do I need a 24V seperate to power the card?
    Any help is welcome
    Registered draughted's Avatar
    Sep 2007
    australia
    yes but it only a 24v 2amp powersupply, they can be had for 20 bucks or so.
    Sep 2008
    P.R.C
    Quote Originally Posted by 6bx View Post
    Pulse Equivalent
    Voltage setup
    Output Pulse
    Any help is welcome
    have you got your controller? for the parameters, you have to set according to your components of the machine. Such as: pulse equivalent is decided by the motor, the ballscrew and the drivers parameter. for Voltage setup is decided by your I/O sensors. Let me know more about your machine, then i can help.
    For the power to the board, yes, you must connect DC24 to it otherwise the dsp controller and other sensors can not be triggered to work. and it seems that you dont have an DC24v output from your SMPS. it is better to use a seperate SMPS to give DC24v to the board. if you use one SMPS to give power to the controller and the motors at the same time, it is not safe for the controller.
    Regards
    Alan
    Oct 2012
    Iran
    Hi everybody,
    I just received my new chinese machine K45MT-S cnc routers with 2 spindles, one vertical and one horizontal. of course not any installation manual and user guide at all. installed and setup by myself and using forums in this sites. but there is some problem.
    I can load g-code programs and doing every things I want as well, but before loading I have to choose and move down spindle via DSP manually and also turn it on and then run program.
    received instruction about M command for choosing spindles and turning on or off but this commands inside the G-code program absolutely doing nothing and this is the problem. I'm pushing DSP menu key 3 times and changing arrowhead of no 2,3,6, or 7 for using and turning on spindles.
    could anybody help me to handle situation by g-code program?
    maybe it's need to do some change inside the DSP? my DSP is 0501 but back side indicated as RZNC-0505HEBC.
    pls help.
  1. Differences between DSP RZNC-D5416 and RZNC-0501
    By KDRusty in forum Chinese Machines
    Last Post: 01-21-2013, 04:24 AM
  2. Problem with DSP controller RZNC 0501
    By oncoarse in forum Commercial CNC Wood Routers
    Last Post: 12-13-2012, 12:14 PM
  3. RZNC-501 host program
    By arzie2000 in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 11-08-2012, 02:15 AM
  4. Newbie- RZNC 0501 Plasma on/off
    By pyrohamish in forum Controller & Computer Solutions
    Last Post: 06-12-2010, 04:38 AM
  5. Chinese RZNC-05 controller & spindle help?
    By Metalmog in forum Commercial CNC Wood Routers
    Last Post: 05-25-2010, 12:20 AM
