Results 1 to 4 of 4
Thread: Workflow w/chinese machine & DSP
    Aug 2009
    Hi folks,
    I just received a price quote from Taney at Quick CNC, and I think the best machine for me is the 1224 (1200mm x 2400mm) that comes with DSP 0501 control system.
    I'm new to the CNC game, and I'm wondering about the workflow that would be used with Albire Design Expert and the DSP system. Go easy on me because I'm not sure if they're compatible, or if I should leave out the DSP control from my order and install a domestic control system.
    I've read that some users have spent countless hours trying to work out kinks with the DSP system.
    Mike
    May 2005
    Italy
    Hi Mike,
    I use Alibre Design Expert. For 2.5D work, you're well set. The machine will allow you to do full 3d machining, where the Alibre Expert's tool paths are not going to help you.
    I initially tried with Alibre Design Expert, and soon the work needs outweighed the software, and then the decision came to either get the Alibre CAM, Pro or to go for an independent Visual Mill Pro. I choose the later. I do solid models in Alibre, 3D models in Rhino3D (mind you it will require you to export to Rhino 4, since it doesn't read in 5 WIP), and export the data to Visual Mill Pro. It works well.
    Remember one more thing, Alibre Design's data export screws up the units. When I send some of my vendors material designed in Alibre, they always get back to me asking me what are the dimensions of the part. So if you have vendors, you should include a set of dimensioned drawings with the exported 3D.
    All the best,
    N
    Nov 2010
    Lithuania
    Quote Originally Posted by jensenium View Post
    Hi folks,
    Mike
    Jensenium from Lithuania?I have to same problemSP book or not?
    Aug 2009
    Quote Originally Posted by nash View Post
    Thanks Nash, that's very helpful. I'll have to check out Visual Mill Pro and Rhino3D.
    Mike
  1. Which chinese laser machine?
    By skalaa in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 07-23-2010, 11:24 AM
  2. Newbie, info on workflow from 3d software to cutting
    By airbrush in forum DIY CNC Router Table Machines
    Last Post: 06-21-2010, 10:05 AM
  3. Need Help!- Chinese laser machine
    By Supo Oluwasakin in forum Want To Buy...Need help!
    Last Post: 03-31-2010, 05:01 PM
  4. Looking for CNC Chinese machine
    By cup67 in forum Chinese Machines
    Last Post: 05-10-2008, 03:28 PM
  5. Gibbs Workflow Advice on Specific Job
    By vacpress in forum GibbsCAM
    Last Post: 03-11-2007, 07:00 AM
