Need Help! Syntec 6mb tool paths not aligned in y axis
Results 1 to 2 of 2
Thread: Syntec 6mb tool paths not aligned in y axis
    Jan 2017
    Israel
    Default Syntec 6mb tool paths not aligned in y axis
    Helppp Syntec 6mb tool paths not aligned in y axis
    Have syntec 6mb
    What can cause misalignment in y axis?
    Pocket tool path off by 3mm in y comparing to v90 tool path..
    Test panel ran perfect befor big job ran..
    Sent from my SM-G920F using Tapatalk
    Sep 2012
    Default Re: Syntec 6mb tool paths not aligned in y axis
    You could have slop in you machine... but probably not.. since the V shape looks ok...
    I would suspect more of a programming issue...
    I don't know if the CAM is greating the GCODE correctly...
    Let us know what else is happening.
    I'm assuming you are making Doors... what software is this from?
