Never mind the program. Your problem is either backlash in the drive system, slipping in the drive coupling, or overloaded steppers. It's mechanical.
Cheers
Roger
Hello,
I'm trying my new cnc 6040, chinacnczone usb https://www.aliexpress.com/item/CNC-...311.0.0.Ja6ib1 and today I made an incision that requires two passes due to the depth of 6 mm.
Two simple circles the largest of which is 30cm in diameter.
The smallest did it without problems, while the CNN at 30% of the second pass, stops for a second and then starts off, respect to the first, the second pass by few millimeters .
The circle came bad as can be seen in the photos.
I had this problem the only other time that the cnc did 2 passes.
Depends on what?? How to solve the problem?
Thank you.
Gcode:
T1M6
G0Z5.000
G0X0.000Y0.000S15000M3
G0X154.096Y105.000Z5.000
G1Z-3.100F762.0
G1X154.127Y104.764F2540.0
X154.225Y104.532
X154.388Y104.333
X154.595Y104.190
X154.820Y104.113
X155.058Y104.096
X155.304Y104.147
X155.532Y104.267
X155.713Y104.442
X155.834Y104.647
X155.901Y104.907
X155.884Y105.197
X155.772Y105.473
X155.583Y105.693
X155.353Y105.834
X155.093Y105.901
X154.803Y105.884
X154.527Y105.772
X154.307Y105.583
X154.166Y105.353
X154.113Y105.180
X154.096Y105.000
G1Z-6.200F762.0
X154.225Y104.532
X154.388Y104.333
X154.595Y104.190
X154.820Y104.113
X155.058Y104.096
X155.304Y104.147
X155.532Y104.267
X155.713Y104.442
X155.834Y104.647
X155.901Y104.907
X155.884Y105.197
X155.772Y105.473
X155.583Y105.693
X155.353Y105.834
X155.093Y105.901
X154.803Y105.884
X154.527Y105.772
X154.307Y105.583
X154.166Y105.353
X154.113Y105.180
X154.096Y105.000
G0Z5.000
G0X104.096Y155.000
G1Z-3.100F762.0
G1X104.127Y154.764F2540.0
X104.225Y154.532
X104.388Y154.333
X104.595Y154.190
X104.820Y154.113
X105.058Y154.096
X105.304Y154.147
X105.532Y154.267
X105.713Y154.442
X105.834Y154.647
X105.901Y154.907
X105.884Y155.197
X105.772Y155.473
X105.583Y155.693
X105.353Y155.834
X105.093Y155.901
X104.803Y155.884
X104.527Y155.772
X104.307Y155.583
X104.166Y155.353
X104.113Y155.180
X104.096Y155.000
G1Z-6.200F762.0
X104.225Y154.532
X104.388Y154.333
X104.595Y154.190
X104.820Y154.113
X105.058Y154.096
X105.304Y154.147
X105.532Y154.267
X105.713Y154.442
X105.834Y154.647
X105.901Y154.907
X105.884Y155.197
X105.772Y155.473
X105.583Y155.693
X105.353Y155.834
X105.093Y155.901
X104.803Y155.884
X104.527Y155.772
X104.307Y155.583
X104.166Y155.353
X104.113Y155.180
X104.096Y155.000
G0Z5.000
G0X154.096Y205.000
G1Z-3.100F762.0
G1X154.127Y204.764F2540.0
X154.225Y204.532
X154.388Y204.333
X154.595Y204.190
X154.820Y204.113
X155.058Y204.096
X155.304Y204.147
X155.532Y204.267
X155.713Y204.442
X155.834Y204.647
X155.901Y204.907
X155.884Y205.197
X155.772Y205.473
X155.583Y205.693
X155.353Y205.834
X155.093Y205.901
X154.803Y205.884
X154.527Y205.772
X154.307Y205.583
X154.166Y205.353
X154.113Y205.180
X154.096Y205.000
G1Z-6.200F762.0
X154.225Y204.532
X154.388Y204.333
X154.595Y204.190
X154.820Y204.113
X155.058Y204.096
X155.304Y204.147
X155.532Y204.267
X155.713Y204.442
X155.834Y204.647
X155.901Y204.907
X155.884Y205.197
X155.772Y205.473
X155.583Y205.693
X155.353Y205.834
X155.093Y205.901
X154.803Y205.884
X154.527Y205.772
X154.307Y205.583
X154.166Y205.353
X154.113Y205.180
X154.096Y205.000
G0Z5.000
G0X204.096Y155.000
G1Z-3.100F762.0
G1X204.127Y154.764F2540.0
X204.225Y154.532
X204.388Y154.333
X204.595Y154.190
X204.820Y154.113
X205.058Y154.096
X205.304Y154.147
X205.532Y154.267
X205.713Y154.442
X205.834Y154.647
X205.901Y154.907
X205.884Y155.197
X205.772Y155.473
X205.583Y155.693
X205.353Y155.834
X205.093Y155.901
X204.803Y155.884
X204.527Y155.772
X204.307Y155.583
X204.166Y155.353
X204.113Y155.180
X204.096Y155.000
G1Z-6.200F762.0
X204.225Y154.532
X204.388Y154.333
X204.595Y154.190
X204.820Y154.113
X205.058Y154.096
X205.304Y154.147
X205.532Y154.267
X205.713Y154.442
X205.834Y154.647
X205.901Y154.907
X205.884Y155.197
X205.772Y155.473
X205.583Y155.693
X205.353Y155.834
X205.093Y155.901
X204.803Y155.884
X204.527Y155.772
X204.307Y155.583
X204.166Y155.353
X204.113Y155.180
X204.096Y155.000
G0Z5.000
G0X118.588Y155.000
G1Z-3.100F762.0
G1X118.629Y153.268F2540.0
X118.756Y151.507
X118.972Y149.723
X119.282Y147.923
X119.689Y146.114
X120.195Y144.302
X120.802Y142.495
X121.512Y140.703
X122.325Y138.933
X123.239Y137.193
X124.254Y135.493
X125.367Y133.841
X126.574Y132.245
X127.871Y130.713
X129.253Y129.253
X130.713Y127.871
X132.245Y126.574
X133.841Y125.367
X135.493Y124.254
X137.193Y123.239
X138.933Y122.325
X140.703Y121.512
X142.495Y120.802
X144.302Y120.195
X146.114Y119.689
X147.923Y119.282
X149.723Y118.972
X151.507Y118.756
X153.268Y118.629
X155.000Y118.588
X156.732Y118.629
X158.493Y118.756
X160.277Y118.972
X162.077Y119.282
X163.886Y119.689
X165.698Y120.195
X167.505Y120.802
X169.297Y121.512
X171.067Y122.325
X172.807Y123.239
X174.507Y124.254
X176.159Y125.367
X177.755Y126.574
X179.287Y127.871
X180.747Y129.253
X182.129Y130.713
X183.426Y132.245
X184.633Y133.841
X185.746Y135.493
X186.761Y137.193
X187.675Y138.933
X188.488Y140.703
X189.198Y142.495
X189.805Y144.302
X190.311Y146.114
X190.718Y147.923
X191.028Y149.723
X191.244Y151.507
X191.371Y153.268
X191.412Y155.000
X191.371Y156.732
X191.244Y158.493
X191.028Y160.277
X190.718Y162.077
X190.311Y163.886
X189.805Y165.698
X189.198Y167.505
X188.488Y169.297
X187.675Y171.067
X186.761Y172.807
X185.746Y174.507
X184.633Y176.159
X183.426Y177.755
X182.129Y179.287
X180.747Y180.747
X179.287Y182.129
X177.755Y183.426
X176.159Y184.633
X174.507Y185.746
X172.807Y186.761
X171.067Y187.675
X169.297Y188.488
X167.505Y189.198
X165.698Y189.805
X163.886Y190.311
X162.077Y190.718
X160.277Y191.028
X158.493Y191.244
X156.732Y191.371
X155.000Y191.412
X153.268Y191.371
X151.507Y191.244
X149.723Y191.028
X147.923Y190.718
X146.114Y190.311
X144.302Y189.805
X142.495Y189.198
X140.703Y188.488
X138.933Y187.675
X137.193Y186.761
X135.493Y185.746
X133.841Y184.633
X132.245Y183.426
X130.713Y182.129
X129.253Y180.747
X127.871Y179.287
X126.574Y177.755
X125.367Y176.159
X124.254Y174.507
X123.239Y172.807
X122.325Y171.067
X121.512Y169.297
X120.802Y167.505
X120.195Y165.698
X119.689Y163.886
X119.282Y162.077
X118.972Y160.277
X118.756Y158.493
X118.629Y156.732
X118.588Y155.000
G1Z-6.200F762.0
X118.756Y151.507
X118.972Y149.723
X119.282Y147.923
X119.689Y146.114
X120.195Y144.302
X120.802Y142.495
X121.512Y140.703
X122.325Y138.933
X123.239Y137.193
X124.254Y135.493
X125.367Y133.841
X126.574Y132.245
X127.871Y130.713
X129.253Y129.253
X130.713Y127.871
X132.245Y126.574
X133.841Y125.367
X135.493Y124.254
X137.193Y123.239
X138.933Y122.325
X140.703Y121.512
X142.495Y120.802
X144.302Y120.195
X146.114Y119.689
X147.923Y119.282
X149.723Y118.972
X151.507Y118.756
X153.268Y118.629
X155.000Y118.588
X156.732Y118.629
X158.493Y118.756
X160.277Y118.972
X162.077Y119.282
X163.886Y119.689
X165.698Y120.195
X167.505Y120.802
X169.297Y121.512
X171.067Y122.325
X172.807Y123.239
X174.507Y124.254
X176.159Y125.367
X177.755Y126.574
X179.287Y127.871
X180.747Y129.253
X182.129Y130.713
X183.426Y132.245
X184.633Y133.841
X185.746Y135.493
X186.761Y137.193
X187.675Y138.933
X188.488Y140.703
X189.198Y142.495
X189.805Y144.302
X190.311Y146.114
X190.718Y147.923
X191.028Y149.723
X191.244Y151.507
X191.371Y153.268
X191.412Y155.000
X191.371Y156.732
X191.244Y158.493
X191.028Y160.277
X190.718Y162.077
X190.311Y163.886
X189.805Y165.698
X189.198Y167.505
X188.488Y169.297
X187.675Y171.067
X186.761Y172.807
X185.746Y174.507
X184.633Y176.159
X183.426Y177.755
X182.129Y179.287
X180.747Y180.747
X179.287Y182.129
X177.755Y183.426
X176.159Y184.633
X174.507Y185.746
X172.807Y186.761
X171.067Y187.675
X169.297Y188.488
X167.505Y189.198
X165.698Y189.805
X163.886Y190.311
X162.077Y190.718
X160.277Y191.028
X158.493Y191.244
X156.732Y191.371
X155.000Y191.412
X153.268Y191.371
X151.507Y191.244
X149.723Y191.028
X147.923Y190.718
X146.114Y190.311
X144.302Y189.805
X142.495Y189.198
X140.703Y188.488
X138.933Y187.675
X137.193Y186.761
X135.493Y185.746
X133.841Y184.633
X132.245Y183.426
X130.713Y182.129
X129.253Y180.747
X127.871Y179.287
X126.574Y177.755
X125.367Y176.159
X124.254Y174.507
X123.239Y172.807
X122.325Y171.067
X121.512Y169.297
X120.802Y167.505
X120.195Y165.698
X119.689Y163.886
X119.282Y162.077
X118.972Y160.277
X118.756Y158.493
X118.629Y156.732
X118.588Y155.000
G0Z5.000
G0X8.412
G1Z-3.100F762.0
G1X8.455Y158.663F2540.0
X8.591Y162.340
X8.820Y166.026
X9.143Y169.719
X9.561Y173.414
X10.074Y177.108
X10.684Y180.798
X11.389Y184.480
X12.190Y188.149
X13.087Y191.803
X14.078Y195.437
X15.164Y199.048
X16.344Y202.632
X17.616Y206.186
X18.979Y209.706
X20.432Y213.188
X21.973Y216.630
X23.601Y220.027
X25.314Y223.376
X27.109Y226.675
X28.985Y229.921
X30.938Y233.110
X32.967Y236.240
X35.068Y239.308
X37.240Y242.312
X39.479Y245.249
X41.782Y248.118
X44.146Y250.917
X46.613Y253.699
X49.161Y256.431
X51.791Y259.109
X54.500Y261.729
X57.286Y264.289
X60.149Y266.785
X63.084Y269.213
X66.091Y271.571
X69.167Y273.856
X72.308Y276.064
X75.512Y278.192
X78.777Y280.239
X82.098Y282.202
X85.472Y284.078
X88.897Y285.865
X92.368Y287.562
X95.883Y289.166
X99.436Y290.675
X103.025Y292.090
X106.646Y293.408
X110.294Y294.628
X113.967Y295.750
X117.658Y296.772
X121.366Y297.696
X125.086Y298.520
X128.814Y299.245
X132.546Y299.871
X136.278Y300.398
X140.006Y300.827
X143.727Y301.159
X147.438Y301.396
X151.091Y301.541
X154.762Y301.596
X158.450Y301.558
X162.150Y301.426
X165.859Y301.200
X169.573Y300.878
X173.288Y300.461
X177.002Y299.947
X180.710Y299.337
X184.408Y298.630
X188.093Y297.827
X191.761Y296.928
X195.408Y295.934
X199.030Y294.845
X202.625Y293.662
X206.187Y292.386
X209.715Y291.020
X213.203Y289.563
X216.649Y288.019
X220.050Y286.388
X223.402Y284.674
X226.702Y282.877
X229.948Y281.000
X233.136Y279.047
X236.263Y277.018
X239.328Y274.918
X242.328Y272.748
X245.261Y270.512
X248.124Y268.213
X250.917Y265.854
X253.699Y263.387
X256.431Y260.839
X259.109Y258.209
X261.729Y255.500
X264.289Y252.714
X266.785Y249.851
X269.213Y246.916
X271.571Y243.909
X273.856Y240.833
X276.064Y237.692
X278.192Y234.488
X280.239Y231.223
X282.202Y227.902
X284.078Y224.528
X285.865Y221.103
X287.562Y217.632
X289.166Y214.117
X290.675Y210.564
X292.090Y206.975
X293.408Y203.354
X294.628Y199.706
X295.750Y196.033
X296.772Y192.342
X297.696Y188.634
X298.520Y184.914
X299.245Y181.186
X299.871Y177.454
X300.398Y173.722
X300.827Y169.994
X301.159Y166.273
X301.396Y162.562
X301.541Y158.909
X301.596Y155.238
X301.558Y151.550
X301.426Y147.850
X301.200Y144.141
X300.878Y140.427
X300.461Y136.712
X299.947Y132.998
X299.337Y129.290
X298.630Y125.592
X297.827Y121.907
X296.928Y118.239
X295.934Y114.592
X294.845Y110.970
X293.662Y107.375
X292.386Y103.813
X291.020Y100.285
X289.563Y96.797
X288.019Y93.351
X286.388Y89.950
X284.674Y86.598
X282.877Y83.298
X281.000Y80.052
X279.047Y76.864
X277.018Y73.737
X274.918Y70.672
X272.748Y67.672
X270.512Y64.739
X268.213Y61.876
X265.854Y59.083
X263.382Y56.295
X260.828Y53.557
X258.193Y50.875
X255.479Y48.250
X252.687Y45.687
X249.820Y43.188
X246.880Y40.757
X243.869Y38.398
X240.790Y36.113
X237.645Y33.904
X234.439Y31.775
X231.172Y29.729
X227.850Y27.767
X224.474Y25.892
X221.049Y24.107
X217.578Y22.412
X214.065Y20.810
X210.513Y19.303
X206.926Y17.891
X203.309Y16.576
X199.664Y15.358
X195.997Y14.239
X192.310Y13.219
X188.608Y12.297
X184.895Y11.475
X181.175Y10.752
X177.451Y10.128
X173.728Y9.602
X170.008Y9.173
X166.297Y8.842
X162.679Y8.605
X159.038Y8.458
X155.378Y8.401
X151.702Y8.436
X148.012Y8.565
X144.314Y8.787
X140.609Y9.104
X136.902Y9.516
X133.196Y10.024
X129.496Y10.629
X125.804Y11.329
X122.125Y12.126
X118.462Y13.018
X114.819Y14.005
X111.199Y15.087
X107.607Y16.263
X104.046Y17.531
X100.520Y18.891
X97.031Y20.340
X93.584Y21.877
X90.181Y23.501
X86.827Y25.210
X83.523Y27.000
X80.274Y28.871
X77.081Y30.820
X73.948Y32.843
X70.877Y34.939
X67.870Y37.105
X64.930Y39.338
X62.059Y41.634
X59.259Y43.992
X56.531Y46.407
X53.877Y48.877
X51.288Y51.403
X48.751Y54.004
X46.268Y56.680
X43.843Y59.429
X41.478Y62.248
X39.177Y65.136
X36.942Y68.091
X34.776Y71.111
X32.683Y74.192
X30.664Y77.333
X28.722Y80.531
X26.859Y83.783
X25.078Y87.085
X23.380Y90.436
X21.768Y93.831
X20.243Y97.268
X18.807Y100.743
X17.461Y104.252
X16.207Y107.793
X15.044Y111.361
X13.975Y114.952
X13.000Y118.564
X12.118Y122.193
X11.332Y125.834
X10.640Y129.485
X10.042Y133.141
X9.539Y136.800
X9.129Y140.457
X8.813Y144.108
X8.588Y147.752
X8.455Y151.384
X8.412Y155.000
G1Z-6.200F762.0
X8.591Y162.340
X8.820Y166.026
X9.143Y169.719
X9.561Y173.414
X10.074Y177.108
X10.684Y180.798
X11.389Y184.480
X12.190Y188.149
X13.087Y191.803
X14.078Y195.437
X15.164Y199.048
X16.344Y202.632
X17.616Y206.186
X18.979Y209.706
X20.432Y213.188
X21.973Y216.630
X23.601Y220.027
X25.314Y223.376
X27.109Y226.675
X28.985Y229.921
X30.938Y233.110
X32.967Y236.240
X35.068Y239.308
X37.240Y242.312
X39.479Y245.249
X41.782Y248.118
X44.146Y250.917
X46.613Y253.699
X49.161Y256.431
X51.791Y259.109
X54.500Y261.729
X57.286Y264.289
X60.149Y266.785
X63.084Y269.213
X66.091Y271.571
X69.167Y273.856
X72.308Y276.064
X75.512Y278.192
X78.777Y280.239
X82.098Y282.202
X85.472Y284.078
X88.897Y285.865
X92.368Y287.562
X95.883Y289.166
X99.436Y290.675
X103.025Y292.090
X106.646Y293.408
X110.294Y294.628
X113.967Y295.750
X117.658Y296.772
X121.366Y297.696
X125.086Y298.520
X128.814Y299.245
X132.546Y299.871
X136.278Y300.398
X140.006Y300.827
X143.727Y301.159
X147.438Y301.396
X151.091Y301.541
X154.762Y301.596
X158.450Y301.558
X162.150Y301.426
X165.859Y301.200
X169.573Y300.878
X173.288Y300.461
X177.002Y299.947
X180.710Y299.337
X184.408Y298.630
X188.093Y297.827
X191.761Y296.928
X195.408Y295.934
X199.030Y294.845
X202.625Y293.662
X206.187Y292.386
X209.715Y291.020
X213.203Y289.563
X216.649Y288.019
X220.050Y286.388
X223.402Y284.674
X226.702Y282.877
X229.948Y281.000
X233.136Y279.047
X236.263Y277.018
X239.328Y274.918
X242.328Y272.748
X245.261Y270.512
X248.124Y268.213
X250.917Y265.854
X253.699Y263.387
X256.431Y260.839
X259.109Y258.209
X261.729Y255.500
X264.289Y252.714
X266.785Y249.851
X269.213Y246.916
X271.571Y243.909
X273.856Y240.833
X276.064Y237.692
X278.192Y234.488
X280.239Y231.223
X282.202Y227.902
X284.078Y224.528
X285.865Y221.103
X287.562Y217.632
X289.166Y214.117
X290.675Y210.564
X292.090Y206.975
X293.408Y203.354
X294.628Y199.706
X295.750Y196.033
X296.772Y192.342
X297.696Y188.634
X298.520Y184.914
X299.245Y181.186
X299.871Y177.454
X300.398Y173.722
X300.827Y169.994
X301.159Y166.273
X301.396Y162.562
X301.541Y158.909
X301.596Y155.238
X301.558Y151.550
X301.426Y147.850
X301.200Y144.141
X300.878Y140.427
X300.461Y136.712
X299.947Y132.998
X299.337Y129.290
X298.630Y125.592
X297.827Y121.907
X296.928Y118.239
X295.934Y114.592
X294.845Y110.970
X293.662Y107.375
X292.386Y103.813
X291.020Y100.285
X289.563Y96.797
X288.019Y93.351
X286.388Y89.950
X284.674Y86.598
X282.877Y83.298
X281.000Y80.052
X279.047Y76.864
X277.018Y73.737
X274.918Y70.672
X272.748Y67.672
X270.512Y64.739
X268.213Y61.876
X265.854Y59.083
X263.382Y56.295
X260.828Y53.557
X258.193Y50.875
X255.479Y48.250
X252.687Y45.687
X249.820Y43.188
X246.880Y40.757
X243.869Y38.398
X240.790Y36.113
X237.645Y33.904
X234.439Y31.775
X231.172Y29.729
X227.850Y27.767
X224.474Y25.892
X221.049Y24.107
X217.578Y22.412
X214.065Y20.810
X210.513Y19.303
X206.926Y17.891
X203.309Y16.576
X199.664Y15.358
X195.997Y14.239
X192.310Y13.219
X188.608Y12.297
X184.895Y11.475
X181.175Y10.752
X177.451Y10.128
X173.728Y9.602
X170.008Y9.173
X166.297Y8.842
X162.679Y8.605
X159.038Y8.458
X155.378Y8.401
X151.702Y8.436
X148.012Y8.565
X144.314Y8.787
X140.609Y9.104
X136.902Y9.516
X133.196Y10.024
X129.496Y10.629
X125.804Y11.329
X122.125Y12.126
X118.462Y13.018
X114.819Y14.005
X111.199Y15.087
X107.607Y16.263
X104.046Y17.531
X100.520Y18.891
X97.031Y20.340
X93.584Y21.877
X90.181Y23.501
X86.827Y25.210
X83.523Y27.000
X80.274Y28.871
X77.081Y30.820
X73.948Y32.843
X70.877Y34.939
X67.870Y37.105
X64.930Y39.338
X62.059Y41.634
X59.259Y43.992
X56.531Y46.407
X53.877Y48.877
X51.288Y51.403
X48.751Y54.004
X46.268Y56.680
X43.843Y59.429
X41.478Y62.248
X39.177Y65.136
X36.942Y68.091
X34.776Y71.111
X32.683Y74.192
X30.664Y77.333
X28.722Y80.531
X26.859Y83.783
X25.078Y87.085
X23.380Y90.436
X21.768Y93.831
X20.243Y97.268
X18.807Y100.743
X17.461Y104.252
X16.207Y107.793
X15.044Y111.361
X13.975Y114.952
X13.000Y118.564
X12.118Y122.193
X11.332Y125.834
X10.640Y129.485
X10.042Y133.141
X9.539Y136.800
X9.129Y140.457
X8.813Y144.108
X8.588Y147.752
X8.455Y151.384
X8.412Y155.000
G0Z5.000
G0X0.000Y0.000
G0Z5.000
G0X0Y0
M30
Cheers
Roger
I agree.Check all your couplings are tight.
Try redoing the job on some scrap, but slow down the feed rate. See if it still happens.
After that , do what I suggested in my PM: wind all the axis by hand to see if you can feel any tight spots or higher loads.
That will take you a while....
Steve
Hi there, are you using Mach 3 software, if you are have a look at my blog, and go to the "My Mach 3 Set-up" tab and copy ALL the screenshots on that page. This will hopefully solve your problem
https://the-cnc.blogspot.co.uk/p/my-mach3-settings.html
All the best
Kev
Read my blog for help and advice for beginners on CNC routers
http://the-cnc.blogspot.co.uk/p/home.html?m=1
